Im wanting to connect a OLED display to my daisy seed. So far I have some basic code that I wrote and some that I found. Everytime I try run it onto the OLED it doesn’t work. Im wanting to just write something basic for example “Hello World”
So I have updated the code. Its working as a timer but for now I want a fixed word eg. “Hello World”
#include “daisy_seed.h”
/** Includes the oled display header (not included in Daisy?)*/
#include “dev/oled_ssd130x.h”
/** This prevents us from having to type “daisy::” in front of a lot of things. */
/\*\* Global Hardware access \*/
DaisySeed hw;
/** Initialize our hardware */
OledDisplay<SSD130x4WireSpi128x64Driver> display;
OledDisplay<SSD130x4WireSpi128x64Driver>::Config display_cfg;
/** SPI Configuration
* Most default values are still used, but here are a few
* settings that are most likely to be edited for custom hw
display_cfg.driver_config.transport_config.spi_config.periph = SpiHandle::Config::Peripheral::SPI_1;
display_cfg.driver_config.transport_config.spi_config.baud_prescaler = SpiHandle::Config::BaudPrescaler::PS_8;
/** Set up the SPI Pins for SPI1 */
display_cfg.driver_config.transport_config.spi_config.pin_config.sclk = seed::D8;
display_cfg.driver_config.transport_config.spi_config.pin_config.miso = Pin();
display_cfg.driver_config.transport_config.spi_config.pin_config.mosi = seed::D10;
display_cfg.driver_config.transport_config.spi_config.pin_config.nss = seed::D7;
/** Command and Reset Pins */
display_cfg.driver_config.transport_config.pin_config.dc = seed::D9;
display_cfg.driver_config.transport_config.pin_config.reset = seed::D12;
/** Initialize it */
display.Init(display_cfg);
/** Set it to black until we start updating. */
display.Fill(false);
display.Update();
/** Infinite Loop */
while(1)
System::Delay(1000);
/** Get the number of seconds since the program started */
int seconds = System::GetNow() / 1000.0;
/** Clear the display */
/** Set the cursor away from the edge of the screen */
display.SetCursor(4, 16);
/** Write the following, starting at the cursor */
display.WriteString("Time since startup:", Font_6x8, true);
/** Update the cursor to the next space below the string */
display.SetCursor(4, 32);
/** Create a string representation of the */
FixedCapStr<16> str("");
str.AppendInt(seconds);
/** Write the value to the display */
display.WriteString(str, Font_11x18, true);
/** And finally push the updated screen contents to the hardware */
display.Update();
Its working but can’t figure out how to do what was mentioned
