I’m new at this and just trying to get a simple dub siren patch working. dubsiren with an main oscillator set initially to 440 that has a button to select different waveforms and a button that triggers an amplitude envelope and a button that routes an lfo oscillator set to sine between modulating the main oscillator, the filter and a null to stop modulation. route the main oscillator into a low pass filter initially set to 800 hz with medium resonance, then into a feedback delay set to 220 milliseconds with medium feedback. Knobs control main osc, filter freq, lfo amount, del time and feedback. I’ve only gotten pieces of this working by cutting and pasting examples into the arduino ide. This seems simple in comparison to the daisy projects in the world. My results tend to be loads of distorted digital sound no matter what. Do I have a bad board?
My method is to use Gpt 4 to help with the coding. I copy paste the modules in the examples that I want to use and then tell it to sort it out in a code. Copy that into arduino ide, find some errors and have gpt correct until it compiles. Once it uploads on to the board the sound is not what is expected. Generally a bunch of aliasing and distortion and not what is represented in the code.
Here is one that compiled without errors but is silent.
#include "DaisyDuino.h"
// Hardware setup
DaisyHardware hw;
size_t num_channels;
// Audio objects
static Oscillator osc;
static Svf filt;
static AdEnv adenv;
static DelayLine<float, 24000> del_left, del_right;
// Hardware control variables
float pitchknob, filterknob, delayTimeKnob, delayFeedbackKnob;
float sample_rate;
// Button setup
const int buttonPin = 2; // Define the button pin
bool lastButtonState = LOW; // Previous state of the button
bool envelopeTriggered = false; // Whether the envelope is currently triggered
// Audio callback
    // Oscillator frequency and envelope
    osc.SetFreq(mtof(pitchknob));
    // Process envelope if triggered
    float env_out = envelopeTriggered ? adenv.Process() : 0.0;
    float sig = osc.Process() * env_out;
    // Filter processing
    filt.Process(sig);
    // Delay processing with feedback
    float wet_left = del_left.Read();
    float wet_right = del_right.Read();
    float feedback_left = wet_left * delayFeedbackKnob;
    float feedback_right = wet_right * delayFeedbackKnob;
    del_left.Write((sig * 0.5) + feedback_left);
    del_right.Write((sig * 0.5) + feedback_right);
    // Output
    out[0][i] = (filt.Low() * 0.707) + (wet_left * 0.707);
    out[1][i] = (filt.High() * 0.707) + (wet_right * 0.707);
// Setup
void setup() {
  // Initialize Daisy
  // Initialize Oscillator
  osc.Init(sample_rate);
  osc.SetFreq(440);
  osc.SetAmp(0.5);
  // Initialize Filter
  filt.Init(sample_rate);
  filt.SetFreq(800.0); // Default filter frequency
  filt.SetRes(0.85);
  filt.SetDrive(0.8);
  // Initialize Envelope
  adenv.Init(sample_rate);
  adenv.SetTime(ADENV_SEG_ATTACK, 0.15);
  adenv.SetTime(ADENV_SEG_DECAY, 0.35);
  adenv.SetMin(0.0);
  adenv.SetMax(0.25);
  adenv.SetCurve(0); // linear
  // Initialize Delay Lines
  del_left.Init();
  del_right.Init();
  del_left.SetDelay(12000.0f); // Default delay time
  del_right.SetDelay(8000.0f); // Default delay time
  // Initialize button
  pinMode(buttonPin, INPUT_PULLUP); // Set button pin as input with pull-up resistor
  // Start Audio
  DAISY.begin(MyCallback);
// Main loop
void loop() {
  // Read knob values
  pitchknob = 24.0 + ((analogRead(A0) / 1023.0) * 60.0); // Oscillator pitch
  filt.SetFreq(200.0 + ((analogRead(A1) / 1023.0) * 2000.0)); // Filter frequency
  delayTimeKnob = 12000.0 * ((analogRead(A2) / 1023.0)); // Delay time
  delayFeedbackKnob = 0.8 * ((analogRead(A3) / 1023.0)); // Delay feedback
  // Update delay settings
  del_left.SetDelay(delayTimeKnob);
  del_right.SetDelay(delayTimeKnob);
  // Button press detection
  bool currentButtonState = digitalRead(buttonPin);
  if (currentButtonState == LOW && lastButtonState == HIGH) {
    // Button was pressed
    adenv.Trigger();
    envelopeTriggered = true;
  } else if (currentButtonState == HIGH && lastButtonState == LOW) {
    // Button was released
  lastButtonState = currentButtonState;
