Hello, I tried to add another class in an external file to my project but it doesn’t seem to be found. The file is in the project folder and VS Code shows it, I added it to the makefile, but apparently that is not enough.
I get the error
make: *** No rule to make target `build/MyClass.o', needed by `build/MyProject.elf'. Stop.
My class itself is correct because it works fine when I copy all the code into the main file, but that would become quite unhandy.
Is there something else I need to do?
Can you share your Makefile?
I think I got a bit closer. Now I get the error
/Library/DaisyToolchain/0.2.0/arm/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld: region `FLASH' overflowed by 106104 bytes
So my program gets tree times as large when I have a class in an external file, although the overall code is exactly the same. Maybe there is some linker flag I have to add or so?
The Makefile is just the one the helper.py produced, with MyClass.cpp added.
# Project Name
TARGET = MyApp
# Sources
CPP_SOURCES = MyApp.cpp MyClass.cpp
# Library Locations
LIBDAISY_DIR = ../../libDaisy/
DAISYSP_DIR = ../../DaisySP/
# Core location, and generic Makefile.
Oh crap, I had removed the debug code from the file but left
#include <iostream>
in it. That solved the “FLASH’ overflowed” problem.
I don’t actually know what fixed the initial “No rule to make target” error though…
It works perfectly again.
