Hey guys.I m working on a project where a arduino send midi to the daisy seed to modify the parameters of a drum machine (kick, snare, hh, cymbal).
The midi work only when the kick is process alone, when i add the other instrument to the audio processing no more midi is received.
Anyone can help?
Here is the code:
#define LENGTH 16 //longeur des séquence max 64;
#include "daisy_seed.h"
#include "daisysp.h"
#include "Sequence.h"
#include "sequences.h"
DaisySeed hw;
//MidiUsbHandler midi;
MidiUartHandler midi;
bool play=true;
bool kickBend;
//instruments
AnalogBassDrum kick808;
AnalogSnareDrum snare;
HiHat< SquareNoise, LinearVCA, false > hh;
HiHat< RingModNoise, LinearVCA, true > cymbal;
//Effets
Overdrive drive;
//Séquences
static Metro clock;
float tempo=120; //tempo à 120 bpm
int position=0;
int sequence_choisie=0;
Sequence sequence[LENGTH];
float volumeKick=1.;
float volumeSnare=1.;
float volumeHh=1.;
float volumeCymbal=1.;
float volumeTom=1.;
float velocityKick=0;
float velocitySnare=0;
float velocityHh=0;
float velocityCymbal=0;
float velocityTom=0;
bool retrigKick=false;
bool retrigSnare=false;
bool retrigHh=false;
bool retrigCymbal=false;
bool retrigTom=false;
void initSequences(){
//charge toutes les séquences
sequence[0].init(seq0,5);/*
sequence[1].init(seq0,5);
sequence[2].init(seq0,5);
sequence[3].init(seq0,5);
sequence[4].init(seq0,5);
sequence[5].init(seq0,5);
sequence[6].init(seq0,5);
sequence[7].init(seq0,5);*/
size_t size)
uint8_t tic;
if(kickBend) {kick808.SetFreq(80);} else {kick808.SetFreq(40);}
if(play){tic = clock.Process();}
if(tic)
if (sequence[sequence_choisie].seqKick[position]>0)
kick808.Trig();
//hw.Print("%d",position);
velocityKick=sequence[sequence_choisie].seqKick[position];
if (sequence[sequence_choisie].seqSnare[position]>0)
snare.Trig();
velocitySnare=sequence[sequence_choisie].seqSnare[position];
if (sequence[sequence_choisie].seqHH[position]>0)
hh.Trig();
velocityHh=sequence[sequence_choisie].seqHH[position];
if (sequence[sequence_choisie].seqCymbal[position]>0)
cymbal.Trig();
velocityCymbal=sequence[sequence_choisie].seqCymbal[position];
position++;
if (position == sequence[sequence_choisie].lenght)
position=0;
//hw.PrintLine(" ");
out[0][i] = out[1][i] =
volumeKick * kick808.Process() * 30. * (velocityKick/127.0f) +
volumeSnare * snare.Process()* 0.4 * (velocitySnare/127.0f) ;
//+ volumeHh * hh.Process() * 0.1 * (velocityHh/127.0f) +
//volumeCymbal * cymbal.Process() * 0.05 * (velocityCymbal/127.0f);
/* drive.Process(in[0][i]) ; */
// Typical Switch case for Message Type.
void HandleMidiMessage(MidiEvent m)
bool hasBeenCleared = false;
switch(m.type)
case NoteOn:
NoteOnEvent p = m.AsNoteOn();
// This is to avoid Max/MSP Note outs for now..
//hw.PrintLine("note");
if(m.data[1] != 0)
//p.note, p.velocity
break;
case NoteOff:
if(!hasBeenCleared)
NoteOffEvent p = m.AsNoteOff();
break;
case ControlChange:
ControlChangeEvent p = m.AsControlChange();
/* hw.Print("ControlChange message du controlleur ");
hw.Print("%d",p.control_number);
hw.PrintLine(" value ","%d",p.value);*/
switch(p.control_number)
case 1:
// CC 1 for cutoff.
//filt.SetFreq(mtof((float)p.value));
break;
case 100:
if ((int)p.value > 0)
kickBend=true;
} else { kickBend=false;}
// CC 2 for res.
//filt.SetRes(((float)p.value / 127.0f));
break;
default: break;
break;
default: break;
/** Basic initialization of Daisy hardware */
hw.Configure();
//hw.StartLog(false);
//System::Delay(2000);
//hw.PrintLine("Ca commence");
hw.SetAudioBlockSize(4);
MidiUartHandler::Config midi_config;
midi.Init(midi_config);
/** Initialize our instruments */
float samplerate = hw.AudioSampleRate();
// initialize Metro object at 120 Bpm
clock.Init(tempo * 16 / 60, samplerate); // click à 1/16
initSequences(); //initialisation des séquences
//initialisation du kick 808
kick808.Init(samplerate);
kick808.SetDecay(.9);
kick808.SetTone(0.0);
kick808.SetAccent(1.);
kick808.SetAttackFmAmount(0.5);
kick808.SetSelfFmAmount(0.5);
//initialisation du snare 808
snare.Init(samplerate);
snare.SetFreq(150);
snare.SetSustain(false);
snare.SetTone(0.5);
snare.SetSnappy(1.);
//initialisation du HH
hh.Init(samplerate);
hh.SetFreq(7000);
hh.SetSustain(false);
hh.SetTone(0.1);
hh.SetDecay(.9);
//initialisation du cymbal
cymbal.Init(samplerate);
cymbal.SetFreq(10000);
cymbal.SetSustain(false);
cymbal.SetTone(1.);
cymbal.SetDecay(.9);
cymbal.SetAccent(1.);
/** Initialize our effects */
drive.Init();
drive.SetDrive(0.5);
/** And start the audio callback */
hw.StartAudio(AudioCallback);
midi.StartReceive();
while(1)
/** Listen to MIDI for new changes */
midi.Listen();
/** When there are messages waiting in the queue... */
while(midi.HasEvents())
HandleMidiMessage(midi.PopEvent());
