No DFU Capable Devices?! Linux
Hello Daisy World!
I got the seed in the mail yesterday! However after getting things set up via tutorials, wiki and forum troubleshooting I just cannot get the device to be recognized. Not through Vs Code, not in the web programmer. I am running Linux (System 76 Pangolin//Pop Os 21.10//AMD Ryzen 7) and nothing seems to fix the issue. I tried several cables and made sure that my usb port is in fact working properly.
I can’t get the Blink example flashed to the seed :pensive:.
Error I get:
dfu-util: Invalid DFU suffix signature
dfu-util: A valid DFU suffix will be required in a future dfu-util release!!!
dfu-util: No DFU capable USB device available
make: *** […/…/libDaisy/core/Makefile:289: program-dfu] Error 74
The terminal process “/usr/bin/bash ‘-c’, ‘make clean; make; make program-dfu’” terminated with exit code: 2.
One other suspicious looking bit in VS code under the terminal Output Tab <C/C++ Configuration Warnings>:
[4/10/2022, 7:41:41 PM] Unable to resolve configuration with compilerPath “/usr/local/bin/arm-none-eabi-g++”. Using “/home/pc84/Developer/gcc-arm-11.2-2022.02-x86_64-arm-none-eabi/bin/arm-none-eabi-gcc” instead.
Once I get past this hump I’ll be on my way to making! Thank you!!! :space_invader:
There’s a known issue with using the WebProgrammer on Linux. There are some solutions discussed in this thread that might work on that front.
We’ll look into the toolchain stuff a bit and get back to you on that!
That’s definitely a bit strange. I daily drive Ubuntu, so I’d expect similar issues and resolutions for a problem like this. Have you tried seeing if your seed shows up at all to your computer with a command like lsusb? If your seed is in DFU mode, you should see lsusb output a line like:
Bus 001 Device 048: ID 0483:df11 STMicroelectronics STM Device in DFU Mode
Thanks @ben_serge, I’ll check into it a bit more on the web programmer side.
@Corvus_Prudens I ran lsusb and the device shows up exactly like you said it should. Now I’m even more confused lol----But at least it EXISTS! So that’s a +1—it’s a matter of figuring out why the commands don’t see it now. :man_shrugging:
Hm, in that case you might try manually adding a udev rule, although I think that presents as a different dfu-util error. Probably at least worth a shot, though.
@Corvus_Prudens
Adding the udev rule has fixed the web programmer issue and my seed shows up! I will continue to see if perhaps re-installing VS Code helps with building there( still does not show up there) and report back if I’m successful. For anyone in the future I followed the ‘manually adding a udev rule’ link AND I had to add myself (user) to the ‘plugdev’ group as suggested. I then made sure to reboot for everything to take effect and the changes to be reflected. Thank you all so much for your quick and effective help! I can’t wait to explore this DIY hardware!!!
:sunflower: :sunflower: :sunflower: :floppy_disk: :floppy_disk: :floppy_disk:
Had a similar issue on fedora 40, this helped get me started, but did not completely resolve my issue. So I tried flashing the blink example from the web programmer, which also did not work initially. There was another post somewhere on the forum that suggested adding the user to two further groups - “tty” and “dialout”. Initially this worked and allowed me to flash the blink example from the web programmer, but then mysteriously decided to not let me flash anything else. Went back to the makefile example and manually set the permissions on the virtual device, this resolved the issue and allowed me to flash my thing. The snippet below show the permissions I used (lsusb should show the bus/device that you need to configure).
> sudo chmod -R 0775 /dev/bus/usb/001/011
As an aside, this seems like a linux distribution thing, I’m pretty sure I was flashing to my hearts content on a debian box a few years back. These issues presented on fedora 40. Maybe the worms ate the brains of the redhat people? :wink:
