Hi, I was wondering if there was any way to extend the number of daisy seed audio outs when used with plugdata
See the Patch which uses an additional codec for a total of 4 inputs and 4 outputs: hvcc/hvcc/generators/c2daisy/json2daisy/resources/patch.json at develop · Wasted-Audio/hvcc · GitHub
There have been some issues reported with using the additional audio i/o though, but since I don’t have a Patch myself I can’t investigate.
ok thanks, and what breakout board do it use?
The schematic says that it uses a PCM3060: https://daisy.nyc3.cdn.digitaloceanspaces.com/products/patch/ES_Daisy_Patch_Rev8.pdf
is it possible to use the UDA1334A instead?
Do you see it in libDaisy or is it compatible with any of the codecs listed there? → libDaisy/src/dev at d336ffad0c38f614a08c6fdda69b3758974a33b6 · electro-smith/libDaisy · GitHub
