Molysynth - a guitar pitch tracker
This is the first version of my little project to understand pitch tracking of an electric guitar, and why it is challenging. The present state is that it is slightly better for me (when I play on my guitarra baiana) that the tracker in Electro-Harmonix Mono Synth, which is the one I am comparing against. Here is the link.
I have made it so that it is totally independent of anything, so you can run it from the command line without any Daisy Seed code. But you can also put it in the HotHouse source tree and compile it into the pedal without adding a single line of code.
Hopefully, someone will have fun hooking up an electric guitar to some advanced synth sounds using Molysynth as a component.
Suggestions for improvements welcome, both for functionality and for performance.
Running it on my Hothouse - fun!
