I’ve got midi working fine with devices that use NoteOn and NoteOff message types. However, when I use a device that sends NoteOn Velocity 0 instead of NoteOff, I have problems. I see there is a if statement in midi_parser.cpp on line 143 that appears to handle this case:
//velocity 0 NoteOns are NoteOffs
if(running_status_ == NoteOn && incoming_message_.data[1] == 0)
incoming_message_.type = NoteOff;
However, when I send midi data that uses NoteOn Velocity 0 for note offs, I find that, while they do get parsed as NoteOffs, I get the wrong channel on NoteOff messages from my program:
// Listen to MIDI for new changes
midi.Listen();
// When there are messages waiting in the queue...
while (midi.HasEvents()) {
// Pull the oldest one from the list...
auto msg = midi.PopEvent();
/* if(msg.channel != midiChannel){
break;
switch (msg.type) {
case NoteOn: {
auto note_msg = msg.AsNoteOn();
voiceManager.OnNoteOn(note_msg.note, note_msg.velocity);
mLog(MIDI, "on channel: %d", note_msg.channel);
break;
case NoteOff:{
auto note_msg = msg.AsNoteOff();
voiceManager.OnNoteOff(note_msg.note, note_msg.velocity);
mLog(MIDI, "off channel: %d", note_msg.channel);
break;
default:
break;
You can see I ran into this when I tried to add a midi channel filter (commented out). With the usual midi device (proper NoteOffs sent) I would get this output:
on channel: 3
off channel: 3
on channel: 3
off channel: 3
on channel: 3
off channel: 3
etc.
But with a velocity 0 noteons I get this:
on channel: 3
off channel: 8
on channel: 8
off channel: 8
on channel: 3
off channel: 8
on channel: 3
off channel: 8
on channel: 8
off channel: 8
on channel: 3
off channel: 8
on channel: 3
off channel: 8
on channel: 8
You’ll notice that not only do the off notes have the wrong channel, but something gets mixed up enough to occasionally assign the wrong channel to note ons too.
I would say this is a bug with libDaisy but I wanted to get some feedback here first before I just submit an issue and hope.
I tried to debug the midi parser class but all I can see as being different when I use velocity 0 NoteOns instead of NoteOffs is the that line 143. I thought the channel might be getting reset there but this fix attempt changes nothing:
int channelWas = incoming_message_.channel;
incoming_message_.channel = channelWas;
I don’t to rule out its something in my code but I can’t see I’ve done anything too crazy here and it all seems isolated to the midi code I pasted from my project.
Please let me know what you think. Thank you.
