Max gen~ compiler error with oopsy examples
hI all, I obviously missed something. I can connect and test-upload using web programmer. However when I try to compile I get a compiler error in Max Oopsy.
Here’s the error code. Can anyone help please? Thanks a lot.
gen~: exported: MAC HS:/Users/hs/Documents/Max 8/Packages/oopsy/examples/reverb.json
param: Param ctrl1_wet has no minimum; default to using min=0.
param: Param ctrl1_wet has no maximum; default to using max=1.
param: Param decay has no minimum; default to using min=0.
param: Param decay has no maximum; default to using max=1.
param: Param damping has no minimum; default to using min=0.
param: Param damping has no maximum; default to using max=1.
gen~: exported: MAC HS:/Users/hs/Documents/Max 8/Packages/oopsy/examples/reverb.cpp
oopsy-verbose: script start patch 48kHz block48 "/Users/hs/Documents/Max 8/Packages/oopsy/examples/reverb.cpp" boost
oopsy-verbose: stop success dictionary u967001065
oopsy-verbose: start success dictionary u495001066
oopsy-verbose: "using build tools found in /usr/local/bin"
oopsy-verbose: "Target patch configured in path /Users/hs/Documents/Max 8/Packages/oopsy/source/daisy.patch.json"
oopsy-verbose: "Building to /Users/hsDocuments/Max 8/Packages/oopsy/source/build_reverb_patch"
oopsy-verbose: "Will upload from /Users/hs/Documents/Max 8/Packages/oopsy/examples/reverb.cpp by writing to:"
oopsy-verbose: " /Users/hs/Documents/Max 8/Packages/oopsy/source/build_reverb_patch/reverb_patch.cpp"
oopsy-verbose: " /Users/hs/Documents/Max 8/Packages/oopsy/source/build_reverb_patch/Makefile"
oopsy-verbose: " /Users/hs/Documents/Max 8/Packages/oopsy/source/build_reverb_patch/build/reverb.bin"
oopsy-verbose: "oopsy generated code"
oopsy-verbose: "oopsy compiling..."
oopsy-verbose: "oopsy compiler error"
oopsy-verbose: "Error: Command failed: export PATH=$PATH:/usr/local/bin && make clean && make"
oopsy-verbose: "xcrun: error: invalid active developer path (/Library/Developer/CommandLineTools), missing xcrun at: /Library/Developer/CommandLineTools/usr/bin/xcrun"
oopsy-verbose:
oopsy-verbose: " at ChildProcess.exithandler (node:child_process:397:12)"
oopsy-verbose: " at ChildProcess.emit (node:events:394:28)"
oopsy-verbose: " at maybeClose (node:internal/child_process:1067:16)"
oopsy-verbose: " at Socket.<anonymous> (node:internal/child_process:453:11)"
oopsy-verbose: " at Socket.emit (node:events:394:28)"
oopsy-verbose: " at Pipe.<anonymous> (node:net:672:12) {"
oopsy-verbose: " killed: false,"
oopsy-verbose: " code: 1,"
oopsy-verbose: " signal: null,"
oopsy-verbose: " cmd: 'export PATH=$PATH:/usr/local/bin && make clean && make'"
oopsy-verbose: }
oopsy-verbose:
oopsy-verbose: "compiler error"
oopsy-verbose: compiling...
oopsy-verbose: "generated code"
Did you do this-
xcode-select --install
S.
yes I did - works now! Thanks a lot lot!
