I can’t download a new firmware on the Daisy seed (i’m using Daisy patch) using make program-dfu. This works perfectly though using the online programmer.
I’ve first pressed the BOOT button and then RESET button like with the online programmer, and then:
raf$ make program-dfu
dfu-util -a 0 -s 0x08000000:leave -D build/PolyOsc.bin -d 0483:df11
dfu-util 0.9
Copyright 2010-2016 Tormod Volden and Stefan Schmidt
dfu-util: Invalid DFU suffix signature
dfu-util: A valid DFU suffix will be required in a future dfu-util release!!!
Deducing device DFU version from functional descriptor length
ID 0483:df11
Claiming USB DFU Interface...
dfu-util: Cannot claim interface
Though the device can be “seen” by dfu-util:
raf$ dfu-util -l
dfu-util 0.9
Found DFU: [0483:df11] ver=0200, devnum=10, cfg=1, intf=0, path="0-2", alt=0, name="@Internal Flash /0x08000000/16*128Kg", ...
I’ve also tried to using sudo dfu-util ..., but the same error is reported.
If you run the command directly instead of through make do you get a more detailed error?: dfu-util -a 0 -s 0x08000000:leave -D build/PolyOsc.bin -d 0483:df11
This could be related to macos security. I don’t know what the equivalent in MacOS X is to udev rules, but could be something like that.
I’m afraid the output of make is the same as running the command directly. There is however a verbose option -v in dfu-util so I gave it a try:
raf$ dfu-util -l
dfu-util 0.9
Found DFU: [0483:df11] ver=0200, devnum=8, cfg=1, intf=0, path="0-2", alt=0, name="@Internal Flash /0x08000000/16*128Kg", ...
But unfortunately the result is the same:
raf$ dfu-util -v -a 0 -s 0x08000000:leave -D build/PolyOsc.bin -d 0483:df11
dfu-util 0.9
ID 0483:df11
Thanks for the verbose output, raf. I’ll look into this and see if there’s anything that explains what’s going on.
Seems especially strange since the web programmer is working for you without any problems.
I’m guessing you have already tried all of the standard USB troubleshooting activities without success? (i.e. Rebooting the computer, trying a different port, using direct without a hub if you were using a hub before, etc.)
I’ll write back as soon I have some more information!
I can confirm the Web programmer is working for me, I didn’t do anything special for it (except reloading the page everytime I upload a new binary because of a bug, but I think it’s a different problem)
For reference, I updated my system to macOS Mojave and the issue somehow magically disappeared. Not sure if it is really correlated, but everything is working properly now
