macOS C++ IDE
I’m doing something similar to @MakingSoundMachines and @dataveg by the sounds of it - editing the .cpp files in VSCode via a PlatformIO project, adding the lib_extra_dirs path to platformio.ini (requires pressing the Rebuild IntelliSense Index button) and then running the make and make program-dfu commands in the VSCode terminal to compile and upload. I find it pretty convenient because you can right click on something in the code and ‘go to definition’ or ‘go to references’, and VSCode will go and open the relevant include files.
Has anyone got a debugging solution working yet on Platform IO yet? Or any other method on mac for that matter? I feel that going beyond simple examples may be very challenging without any debugging!
@adam_f I’d be interested in the debugging possibilities / methods as well! Hints would be welcome!
Hi, yeah I managed to get the debugging working (with a ST-Link and JTAG adaptor) in VSCode on mac last night, with the help of shensley over on another thread. As far I remember here are my steps:
Install Daisy mac toolchain with homebrew as per the Daisy wiki.
Update ST-Link firmware if not up to date - I had to do this on windows, as STLink utility is only for windows.
Plug in ST-Link to Daisy using jtag connector
Also plug in Daisy to computer using USB
Install openOCD using xpack: https://xpack.github.io/openocd/install/
(also need to install xpm, follow the link on that page)
Add openOCD install path to $path from terminal:
sudo nano /etc/paths
ctrl-x to exit, Y then enter to save.
Start a fresh terminal.
Test openOCD from terminal with:
openocd -f interface/stlink-v2.cfg -f target/STM32h7x.cfg
You should get an output like this:
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : clock speed 1800 kHz
Info : STLINK V2J34S7 (API v2) VID:PID 0483:3748
Info : Target voltage: 3.175214
Info : stm32h7x.cpu0: hardware has 8 breakpoints, 4 watchpoints
Download and install GNU arm tool chain:
https://developer.arm.com/tools-and-software/open-source-software/developer-tools/gnu-toolchain/gnu-rm/downloads
Install Cortex Debug extension for VS Code (search for it on VS Code View -> Extensions)
Download STM32H750x.svd file from here:
https://github.com/posborne/cmsis-svd/tree/master/data/STMicro
Copy STM32H750x.svd into main .vscode directory
Create new workspace in VSCode and put the DaisyLibrary in the directory
Create project folder and write .cpp file or use example file.
Copy in make file example, change to correct paths and file names
add in line: DEBUG = 1 to make file (new line under Target = XXX)
In a new terminal in VSCode cd to project directory and type
make
This will compile program. Then press reset and boot buttons on daisy and type (in terminal):
make program-dfu
(should now flash Daisy)
Create launch.json file in VS Code by clicking on Run -> Add Configuration
Replace all text in launch.json with the following:
    // Use IntelliSense to learn about possible attributes.
    // Hover to view descriptions of existing attributes.
    // For more information, visit: https://go.microsoft.com/fwlink/?linkid=830387
    "version": "0.2.0",
    "configurations": [
            "name": "Cortex Debug",
            "cwd": "${workspaceRoot}",
            "executable": "{$workspaceRoot}/build/YOURFILENAME.elf",
            "request": "launch",
            "type": "cortex-debug",
            "servertype": "openocd",
            "configFiles": [
                "interface/stlink.cfg",
                "target/stm32h7x.cfg",
            "openOCDLaunchCommands": ["init", "reset init"],
            "runToMain": true,
            "svdFile": "./.vscode/STM32H750x.svd"
Update executable location to point at your recently created .elf file.
Hit debug button, then green triangle at the top left (Cortex Debug). Add in breakpoints and watches as necessary, step through program in debugger.
Hopefully that helps! The Cortex Debug extension supports other debugger hardware as well, but I haven’t tried.
Cheers,
Adam
awesome thanks for the writeup! will try this later!
I made this to attach Daisy to eBay clone STLink.
Bought a double-end header cable and used half.
Partial success. Thanks to Ethan I have now built a working example with STM32CubeIDE on Catalina and flashed via clone STLINK to run. At least this supplies a single write to flash setup without needing Boot/Reset presses.
It’s only partial as I don’t have the Debug facilities working (yet). Seems a common Eclipse issue so can hopefully crack it.
Actually, seems such a common topic because hard to crack! Tried a myriad of -g -DDEBUG flags without success.
What are you guys/girls doing for debug? I don’t have an ST-Link (and I’m not sure I would know what to do with one). Is there a way to print back to USB connected term like there is in Arduino?
I have USB serial working in PlatformIO + Atom with the following platformio.ini settings:
[env:electrosmith_daisy]
platform = ststm32
board = electrosmith_daisy
framework = arduino
upload_protocol = dfu
build_flags = -w -D PIO_FRAMEWORK_ARDUINO_ENABLE_CDC -D USBCON -D
USB_MANUFACTURER="Unknown"
I don’t totally know what those settings do :slight_smile: I yanked em from Difficulty with getting USB serial [USB CDC] working. Generally speaking, I have no idea what I am doing, but hopefully that might help!
