First off, I searched the forum for solutions but couldn’t find anything that helps.
I have two related questions:
How do I set up a sample project like, say pod/MultiEffect, in Visual Studio 2022? There is no .sln file. I can open the folder in VS… and then what? Basically, I want to be able to jump back and forth between MultiEffect.cpp and the libDaisy + DaisySP code.
I resolved some of the libDaisy build errors that looks like were happening due to folder conflicts in the STM32 Devices installation. I had a set of older HAL drivers in my project folder and newer ones in the /AppData/Local/xxx installation.
I simply copied the newer folders and overwrote the older ones in my project folder. Now I’m getting different errors that are not due to my setup anymore.
I’m not sure what to say, this is a first… I never encountered a situation where the software is knowingly released with bugs.
I don’t know how to make Visual Studio ignore those issues when building.
It looks like no one here experienced anything similar, probably everyone uses rebuild_all.sh or has an older, functioning version in their VS. I guess down I go the rabbit hole again looking for some fix.
I got again from Github the drivers from the libDaisy repository
I don’t get anymore any errors in STM like I was getting for DMA_SxCR_TRBUFF.
However, in libdaisy.vcxproj.filters and libdaisy.vcxproj there are many compiler references to various .h and .c files that simply don’t exist. I removed them manually from those two files and the libDaisy builds now successfully from Visual Studio build. Not sure though if this will have a negative impact.
All in all, the implementation of the libDaisy VS solution seems to not be mature at this point. I wish I had known this from the beginning and save me the many hours chasing my tail.
