After updating my M1 MacBook Pro to Sonoma I’m no longer able to program and debug Daisy Seed via ST-Link V3 (Minnie).
The first issue I had was that I couldn’t compile until I upgraded (and reset) the command line tools. For those having the same problem, after updating the tools you need to run this via Terminal:
xcode-select --install
Now I can build but when I try to program I see this error:
Open On-Chip Debugger 0.12.0
Licensed under GNU GPL v2
For bug reports, read
Info : clock speed 1800 kHz
Error: open failed
in procedure 'program'
** OpenOCD init failed **
shutdown command invoked
make: *** [program] Error 1
* The terminal process "/bin/zsh '-l', '-c', 'make program'" failed to launch (exit code: 2).
* Terminal will be reused by tasks, press any key to close it.
* Executing task: make program
Is there any way to get more information on the error?
