I am making a nice little tap vs tap & hold function for my buttons.
This it occurred to me - is there already a library to handle this in Oopys and/or GEN?
So far, I have tap and hold working well.
Started working on the “tap” part and would prefer to borrow code here so I can keep on with the core of the project.
Thanks for you help.
Brett
Simplest thing is to run a timer and grab the time when the button is released. If it’s below a certain amount, treat as a tap, otherwise as a hold.
The simplest timer in gen~ is [accum] aka [+=]. Send a param button to the 1st input of [+=] and it will count in samples while the button is held, and stop counting when the button is released. So now you want to do two things: a) measure the time when the button is released, and b) reset the time to zero when the button is pressed again. Both of these are edges: a) happens when button goes from 1 to 0, b) happens when button goes from 0 to 1. Send the param through [change] to detect those transitions. Change will output 1 when the input rises, -1 when the input falls, and 0 when the input stays the same. A button outputs a step function so button → change will output single-sample spike of 1 when button gets pressed, and single-sample spike of -1 when button is released. So, send output of [change] to [== 1] to 2nd inlet of the [+=] to reset the count when button is pressed, and output of [change] to [== -1] to detect when button is released. Send this spike to 2nd inlet of a [latch], send the [+=] to 1st inlet of latch, and you have what you need.
Hi @grrrwaaa,
Thanks for the info! Looking at your code idea, seems a little simpler that what I created.
I suspect I’ll have to iterate on it, given what you noted above.
Here is what I ended up trying out… not sure it is great, but it does work.
----------begin_max5_patcher----------
1551.3ocwY01aaaCD9yo.8+.g9PWBliJeUhrao.sceY.aXEXqXenYnP1h1Qs
xhBRT4kUz+66HkkeKJJNyNMFHNRGORd2Ce3cGo+5ye1QAiMWqqCPuB8QzQG8
UPxQdYNIG0I3nf4IWOIOo1qXvDy745BavnEMZ0Wa8M7ymdJpoVixSrSt.YMn
uXtBUkUmULCkTjhlljm6dVmNSiNuvo9wmRPm00vHzO5dqsGmrb7glzSLME9I
g1IsrRWCVQhMyT7oMTg0oRQy7rhbs0a1j0jZZrchwchyR89fY7mOksbpKcdB
XLepROw1hRLAOjvEwDVrhH4wTNaDhnjgRgDjpXJdjjw3iPTFMTwIRrjfUTIi
6zjwCwn+wO7e64Oy8e3ei1er+WmhJLVTxDa1k5QnTSwOXQdHAc5ouNXegD5P
Phj0ChHvfPpLhJDRVDWFIcBkafHB.jvON3gibka.xlimTirYy06MHPFBD3LQ
On.UABcuoH.ufiUNTHN9.iBE5q.661ffeiX+tMse2lziayiDCtgfPBoR0pOQ
NtOlu4FBEok6CMQc9Z2.1N21aJ0siVPvdwFR0NU5F7olBaQxb+PG7aMSxRSP
uyTTaxuCx.a8dNMYhdCpvt.U7gfJBUDRU.IQEGQvTIkDC3AGhcHURIW.bFtf
iABA.YgfRQDVDi.ZHTNMkRGaBXRRNPonQpngAx08l5r+02BAf+N4N7xa6uyE
n3OtTWMMGBYeFJqf7SmWcdgWt+cp+821XslhOT9KlqJ7hYdwt+d4KQuA7W8k
5TTB5udy6QGClTYiq6jSZ0Xgdiu4UnjSPenHUWsX+oK8vEl7Tj8B3c+SG2YT
NaZw.fbeFeB5u0nKRtTCSzT8Un5j4k4ZXS9EI1V4yLEZXZPG6i.tdmmbBp0I
PY0H36YFWFolRzwkl5LWvSDrLOFLroUl4HrKMF4DDxMDYSOdKf5LPgW7BTKL
8Zjv8xlXTmy+UONYAHwkhqEc+1ZX2sgvs.l9PvxjZ6ZH1X8jDW92kFoyFA2b
VkNwBdDfOEH7pARmCJeKm50HbOVb65+41Mra2.baUwqbtfCdHs5II4ZDNDQC
ceSB2+vaB7P6YowjvHNIBSiXTH5FKJZDRHhCILJA1IC6FwP7MPnB+nGd6NR1
8dGS4Es7j8NKGmNX3dZD9144TQOko4j86yOj31zA4.rXQnJRwYXIDXlFK3JG
G.JuinHQPDcrJVgcBIpGYNvcgAklu.EdqSq6GK3Oj0exvo6gRZHPloX.K3RE
wsvFggR.IRHcEjdRPgcKQNgqvhCt+R160bRzCmmCoh6op1mp07yNauC9QFtf
k9AgHVHrUXsOtZSTghmDPvmgWWcO0ysIRv5EIF7LNTdOk22aUt7chNLZweOF
HBjle1C6zN8SMFLN.UEC0xtFIfdGLCn71mnPhIUIyQeQeyaODAKv2KX.7.JW
ohE.sfGeGAKhepBVLu1ZbEJWu+DCgb3KHAGxWKYI2UaTuLiX7SDVvXr8mQHh
GDETjdPg9XDz+eLhVk8WN112em2bbMrE1TaZplzMhKSAhVadS001rB+cpsgZ
7V0t6EhGvTx2sojd.mRxtOkj0VDpfym5ymdHLB2llc0HnGH+Fu6qt842jumF
wVqQKMB7AvH7k2e+FguxWGRbP76EKj2yTdP2ZQ2Iura89P.r61tY+QrOPd4x
wZWVKOPS4tElrELneOiY0ZYjGosMOHi.+XE.wkmcGBfzEes+zjIkkWpqpWzm
1YCpU3yFucJG09dVQ66s46CpzWl00ERaoAAIUPldKjluop8pSut6DTAyMfaW
zj044NG1M201axuUN5kWK8aZRyL+oMw1T+oeWWzrnnBvMmlzja2BdFOaZVd9
DSdqgdzplfxaVTtPPayi5juT6OhvtqeFNnNfTgL3nLzH+SvCBw57nEchz0Kt
fqbE36prCpkQ3eRRYBl6I718itZ1vDU6bfURLu8IPDbNIxF8CNxRt25o9pB6
DWVYJMUcq0PmUq5Qi0LqJIMS29y90x36V56PeOUqBTwuJ3gmNDdN.uYK64Jt
hu9Q25Sc4heAffz5xvYZ20YBp8ef6g8YV
-----------end_max5_patcher-----------
Thanks,
Brett
Try this:
1894.3oc0ZkziaaCE9rmeED5TB5TCQsY6Bjhza8PAZPu1VXHawwloxTBhzyR
CR+sWtIapERI6YFOdNjwQ7QI8deusOQxucyDuUEOhndfeB7mfIS91MSlHGRL
vD80S71k9357TpbZdj86Vgp9OuaUxvYxQKV80eLodr6JHLJ9eQBIvfo95g42
YwdVNhIePA5Qo3MhK8OLM0bXOUhTpkXFjzbuaAd2kWjx7.+sw6gjtSNOueoB
KljRRYJa8VLYyxJzZl5wDNW7J.AwPwOwIxK3J2gm1thLjohId52ktVNlgIfI
Gr.wXe+laD+41Qhd436QSoqKJQ8gfwd8BUPaHypTxlivQOFcvr4FF87Eh+Ft
vvne1FTJiUsG2isD41VD2mbtq1yXEDOigWlgok4oOIDGpGWOTsOZtMDwIZ.m
I85vH0Ow9chAZ.GvWb+avKs+UaQuh9WB5AtlWq2Lzix2r2FDoOCD1uAFNbpc
m+2XbjKhTdvvAbjlOITk1Z0lKOQGmitGUQw7vviylGKVVZL7DiaQfQesnxHR
TLDlnFBdXnJz8356+3DSq31CiaL6qTktdLoNYQWFphvSopi.kdKsJI8KhRdz
RckIuLZ4Tt2n9A3YfR9x3AXfrFPhuLbORD0WCSbm+l7h0+CJynHG2MUhHXRY
EhhHrTl1.NHNCcW59b1x9Ky2TdqBnME1as6IdapvYEDgRzvcHFt90wMtXUNr
owHmAIsrmalGbxwEKBobibOcUZkvasJ2rK.OjunHuonC2WN5NlVbIlPZghrh
R6Bqva153dWUvEty0yVJgtbOQIcIOvfsjldeSzlklmqyfa93eLkf2kxPLrxE
D3ePHhjxMzsz0UE44MrWkj66QRFOPeM5AbFaail4BI7oiKqCh7N3kyvaPTVy
wXoanMGgxdRA5FCsekNQdICsi2Uf0ZB7TDLkQ2V7.UOw5.MS.3HqGyDayxgM
F2UYwlkF4E4.PP49bJ52IegmDQMmlY2.eSAMqX5aHomBf5VWIAxj.XT65eVZ
lMot9utpxqiwGB1Q+UTdlMyFd1lcHze5r3CF9rEWU1c.3KJm9efxQoTjM6O3
rse3rnoGMeXvE19WWraGuifM.njiA6nfsbWOnfj+D3gsHBPwuCTovjFAE4XB
ZcwdByrfaazJ47iVhVHiVfygF78BCuBBWxEZqs3iH6VLzPhctuCk9nAjvQT1
H3xfGbBLfOyvbCRGu7aEavqsAPg1AnPm.zs5+MDPohTfb3RjsMSEFMPdV6m3
QdlMwDq7Msw4r0s2G2SK7OsyAcXdn13h1fO5H4j1lWpJvCFKosmnHwGMedS3
setoife5X3nNHO0QxU0Ae0wwYc.dqCxccP9qCvgcXdrCxkcD7YGCm1SgWqCt
sCxu0MGW27bcy00IeWabd6m2qEtuih+6H4.2OO31EaZWaui7AoHzrP+5BT0Z
Dfm8xIKvJ3Dk+P4d5VT1GAEU.evGp4I7w1OByz8k1XNXaAWFl.gsVAp0TYlp
UYr5G+VIv1YQznyYytmOWjtS2zl.Mlvw1FqsVe3CzM9.aI0MkCqcSiEsQij8
TSh6iyQWDz+sGAoo6Jo7JVTW32rKA.FtX9z.ACjEKDH4L+wggWhnvgy2Ib9L
xT8c37bLkm1RxbBoQO6b1HEBE5GJfq50488PV6m9DnaNoI3DbIh2BBTDzlI+
LyvYumB238D.hL2bDEfxSK4sR3eGJ9vGV.vTPVwCja+KhngBCntkTVsbQeFJ
fSoppyqoQWmHGdI3yODNbt7aOBVXDBm7NID1UD7hKWGGXRh3mvv2OwuvFqYh
fYjJRjxKKz6xobKmyDmGLnfwo3ADrcoScF1FZ20L6YG0BgpUZwOxXAWhl8NH
pc81TxFji313KXbKTF2FM+5Itc.z6G9jCjK7hRQh2sRxTZZ7Xvtf2dr6mA9t
Z3eAqWp+Hmj2MgcN2oEm61x4UdSASggwN10kqVfpmckw4NybdPTcdnFj5eGZ
tZwHG6fiycw47vJMM653ofW.rp45JJZ7Ovp6HUKw7bCjzh8UqqKonKpC5pmY
HJCSNrhr+4wORVL4yxGetJn3KkFsFFD7FngKNEEzu2IWTko1lA3kEaOAMu+.
kc3rxBLgoiNUqJThpzQj+L49sHuztI6eYM4SwaE+VDueJIjKtphllcJIBv2.
rM9DTvqJncwIlnBGWhZPf7mHnlycP7T+qkD0SwWYoGQu1LLQ9osAgp0TTb04
YxFwtGk7Je3Lzqcfbcu3Fr7h8kV1d84m8AtHHT9A+wwlGuV+qfiaQYZU5t5k
N4y72OGD9L+larRU11WjWzifQrIBoVeU2mq.+dPnim3wNL7NBZ8k.Y.cC2.w
VE3vlUfc54NUkPb1WFmV.eM0hN0BGf2nYHQmJ8u7p1n.H+qB.JpyD6Vj7kW0
BFqp0O.oGTMh97xKehMy2TGe91Jn9Pz2a90A8xhNkbTk5bL8Ok2Cbf2S7Kv6
oQlpsFruP1yPumfNuGk6p0ooR7JZc5oZcpo5dZoreJoZe5njmJp9NMTh1W27
8a9e.cxDciC
Here’s another variant; this one will give a single-sample spike for a short-tap, or will set a gate high for a long press.
1933.3oc0asriaaCEcsmuBBsJEcpgndXaUfjltqKJPC51jBCYKN1LUhRPjdl
IMn8au7kr0KRIO9wLdQFGSRIcuGdt26gTze+tINqxeFQc.+L3yfIS99cSlHa
RzvD82m3jE+75zXpbXNqyyxPDly8p9XnmYx1SyIa.EkH9vzcgSjcju5q+Dzq
pQxtr7crTDSd2b0sVDyVuES1rrDslorFXXzT26A9dghOVLS7WO2otf+5vcBS
ptQPQa+6c2I9y8mnmP2lWxL6Jvi1UBmeg8jT7inoz04En+qGKNreCFpaU0D6
aEHk05rJlrwYuwYdpwa9BoColmhL4Pdu.GJlwJ2g6wWBr6KhqSN1U6XrbhSs
lWlfoEoweSzsutccSY4IReegIDwJZnlc8fPwGvPW427tdSudm6oWsCc4lcIn
m3Fdm3tMHx+A9HCysWvWbn4YHfZZDjluAul9Em9BG6268L48T7FRbpy86+ei
.IBjgrvEdCL0V+FgJ0.fFAl37.NE8Hpjh47xCilSNKJp07jZWh.19ZdYMpon
ILQ0DbeSknGwUW+gAFWxcGF2W1UJcdmmmUE8HtMbNeIgGiUwIkSfZSRNUQhy
Pzh30pKNgVLkOAUcCbpkMvURQfdR9xLWY.PPXsDbb9vlz70+MJoVhR9bSAhf
Ih7r7rvwLsCru6DzCw6RYKeHmvn3+QZFPwTPO8+f1L6sSgiH8gesDKl50CYS
INImHLhFSGhlqdbhTcpn55NibDj3hdtXNijiKF5jxcxczUwkhYqUonZ7TdTP
ddZyt1econGX5tKvDRKTjkWXtyR7lsVt1U47Nyrcuk8PWtin5cImXvVRierI
ZyhSS0A0Mu8OGSvYwLDCqlB7b22IhDyczsz0k4ooM7WUOO1SOIbh9ZzS3D1V
4CpNYfObbQEIxY+rbBdChxZ1FKdCsYKT12Tfdsl1sRGHujgx3kIXsF.ODASY
bwBOQ0CrhnUG.NHtpdfc8LjMZ2VlxlYKiII0auVJQe+5czaUgAJyYJenOzc5
7Pd7PjpXm6hogMyHZn.wjphD57Lme33WLAFvKEXHTA4WCMB5T4uKX3ec.iO.
DpwkJXWlQMfLdQWbZRfrjPTvv.C75.LEwkwYM.GPnqqI.ZwkBfBfRHQiOvfQ
.PtWG.h6K.uC.jIjwRPk633FddRQUpPm2DbCgqCAr3BSNs2K1o2mpP60gguY
7ZtltJM2Jw1+tPqsIHvRkEeqQD2q+2PQFpkOA4jDAZMORyUrBTsuiGjd2DSL
JA2jL7VWdexwMHI2rr7gklaRddCI5iTldao59p7Ng9Ro5pDyAKVzDd6Wt9Hj
rOFY6CJcejx2sHgebx3GPJ+fx4GTR+.x5GVZ+fx6GgD+wHy+Xj5aQt+fR9sK
62tze6x+stD.SKCn+kBXX4.iZIAibYA8uzf1IaZmauS+V2MytI5WmiJWi.7n
WdcNVNuT26J1Q2hR9APdIvE7tRTJJlx+d6aQ8v8koXBZc9NBqMU2vtRMbASS
kBT67zbk1nvf16Z5.UMaT4rY0ySEo6TMsIPiIbrsw9O1G9.siOvV8ZWiowpo
ghxnpElLqWMGVDZ95gfz3rBJOiE0F9M+Z.f9QKl5ITfDEIPx4tiCCuFrvgi2
Ib8LxP8LbZJlxCaIIVgzfSNlMPgP9t9B3pZyvuEhZe+6AciI66MXcQ4addJA
Zyka0r+7aI5Ful.PD4lhn.TZbAuTB3os38Kr.fofj7mH2+EhnfBCntjXVU+x
UbB3RpJ67XZT0IvxrD7zov95M0JpFEd1MBE1FCN55UwANal3Ce+aG9KjyU4K
EthJxUFoXhTdZgFcUIS5dtlItNXPNiKwCHT6RmZk15adpY9IyZg5W+naPs2B
Yv7a.V65swjMHK71vqHuEJ4spsk6sAuc.z6GeuEjy+pJQhWsRpTpuWIfkWKv
qG18AfqsB9Ww7k5E4L6lg1o1qzhcoTzeP9TqcJtyRAcO4zaJXx2WsMNvfaJf
xGjQ+MTZhMH5z0sTEGpAo4Q2TXjG3SJxzepJuZCqN8sVPKythO4cFvpl6qnn
v+.6tizrDiyNPRy2UttJkhNoNnqclfnLLY+Nx94CKRVL3Wzb7K0.EqTZzVnm
2qfEFcLFnauCNuLQ8ZFfWWr8Hr79IJY3jhbLgoYmpcEZlJ0Qf6b46aQ9Uytr
600kOlYqvWC99wDPF8lhMM+XBDfuBXa3QXfuof1niLPENt.UO0YHN.p0b6EN
08sRf5wLWYnFQu9Lbl5LB3q1SQw2dYtbMt6gdNCuc8tasPmsUPtuWbGV9kcl
NgAKdwGv.Oe2Cmq.Ca65q3AtQu0Iej+74fvG4Wbicpxz6E4rdlaBqiPy8dYm
3lCGBzNJ7N.Z8E.UC5Ft.ho7DcRTzNfITt3a06pHvUc3IDeqw0zMVwJE3X8F
uniwcbullVOOwwUq67BPBqvaLVQzk1JfiYZBpL2WYxBzLYAdYHKiMrr8RXNq
VwnMB+iCezlqpE8OeC4U2Lwl5WyQaiV+a5nWicOkZXE5c9UiL1mSPce0jBiy
vyANhmiWmmiBFacbxDOhVGerVGartGWLyGSr1GOL4wBquiCln98c+6c+OEAo
5W.
@grrrwaaa,
Thank you, this is much cleaner.
Brett
