I2C Receive Blocking not working
Hi all,
I’m using a Patch SM that I want to receive data from a Teensy. I have tried this out via the Arduino IDE code and it works but under C++ it’s not working as a Receiver. I have changed the direction by having the Patch SM send data to the Teensy with no issues under C++. To me this proves the I2C init is working fine.
Here’s my code:-
#include "daisysp.h"
#include "daisy_patch_sm.h"
#include "daisy_core.h"
using namespace patch_sm;
DaisyPatchSM hardware;
static I2CHandle::Config i2c_conf;
I2CHandle i2c_handle;
I2CHandle::Result res;
    // hardware.Configure();
    hardware.Init();
    i2c_conf.periph = I2CHandle::Config::Peripheral::I2C_1;
    i2c_conf.speed = I2CHandle::Config::Speed::I2C_100KHZ;
    i2c_conf.mode = I2CHandle::Config::Mode::I2C_SLAVE;
    i2c_conf.pin_config.scl = DaisyPatchSM::B7;
    i2c_conf.pin_config.sda = DaisyPatchSM::B8;
    hardware.StartLog(true); // start USB monitor
	// initialise the I2C
    if (i2c_handle.Init(i2c_conf) != I2CHandle::Result::OK)
		hardware.PrintLine("i2c init FAILED!!!");
	else
		hardware.PrintLine("i2c initialised.");
    uint8_t rx_buffer[1]; // Buffer to store received data
    uint8_t target_address = 0x40; // Example 7-bit I2C address
    while(1)
        res = i2c_handle.ReceiveBlocking(target_address, rx_buffer, sizeof(rx_buffer), 100);
		if(res == I2CHandle::Result::OK)
            hardware.Print("-%d-",rx_buffer[0]);
        else
			hardware.Print("*");
I get no compilation errors. The i2c reports that it initialised but all I get on the USB monitor is * which is the response for no data in the buffer.
Any leads would be greatly appreciated.
Steve.
