I have the Daisy Seed working perfectly with code running on the internal flash, but obviously 128kB fills up fast.
How does executing from SRAM work? Where is the firmware stored before it is loaded into volatile memory?
Is it possible to execute main code from SRAM and then also load large lookup tables into QSPI_FLASH where they can be accessed with a modicum of speed?
Can/is firmware stored on an SDCARD loaded directly into SRAM for execution, or is it copied to flash somewhere and then loaded into SRAM at runtime?
