I am posting this here in case it can help someone. For quite a while now I have been scratching my head as to why I could not get some repos (AULIB, SOUNDPIPE, etc) to build. They kept giving me file not found errors for libraries I knew I had already installed. (i kept getting Sndfile.h not found errors , etc)
Today I finally found a clear cut REASON For my issues and an easy fix.
(you can find the answer in this stack overflow thread)
HOW TO MAKE OLD C REPOS BUILD ON M1 OSX
- Make sure to install all dependencies for your repo
- RUN MAKE
- If you get “file not found” errors which are related to the Changed M1 lib location then run
export CPATH=/opt/homebrew/include
export LIBRARY_PATH=/opt/homebrew/lib
for those like myself who are still pretty new to using Make (and like me you have even tried to edit the make file to see the new OPT/ location with no luck) then this is a really amazing fix.
(I guess this brings up the question for me–is there a good book or article or youtube video which goes over editing makefiles? )
