GPIO for pd2dsy
Hi, I am using the daisy pod with pure data, but i would like to use also extra sensors (flex and sonar). How do I read the analogue and digital pins in pd2daisy? I could not find any conversation about this. Example: I have a variable resistor connected to analogue 1 of the pod and I would like to read it inside pure data (same as a knob) what hv_param object can i use for it? or any other way?
Thanks a lot.
Hello!
We can think of Daisy Pod as Daisy Seed but connected to a breakout board with knobs, encoder, LED, audio jacks, and etc.
In order to do custom hardware configuration, you need to use a custom json file, which needs to be created & saved in the same folder as the patcher that you’re flashing into your Daisy. I usually just make it in TextEdit and save it as .json. Make sure you’re using plain text and not rich text.
Daisy Pod, which you may have noticed, only has two available ADCs as the other ones are already utilized. So, the available ones are ADC 1 (pin 16 in the JSON file) and ADC 9 (pin 24 in the JSON file).
You can see which pin is which here.
So for testing, you can set up a Pure Data file called “project.pd” and a “customseed.json” file and save them both in the same pd2dsy folder. Then run this in the terminal.
python pd2dsy.py -c customseed.json project.pd
customseed.json will look like this. Notice how your Flex sensor is mapped to pin 16 and Sonar sensor is mapped to pin 24?
	"name": "customseed",
	"som": "seed",
	"components": {
		"knob2": {
			"component": "AnalogControl",
			"pin": 15
		"flex": {
			"pin": 16
		"knob1": {
			"pin": 21
		"sonar": {
			"pin": 24
		"sw1": {
			"component": "Switch",
			"pin": 27
		"sw2": {
			"pin": 28
		"encoder": {
			"component": "Encoder",
			"pin": {"a":26, "b":25, "click":13 }
		"led1": {
			"component": "RgbLed",
			"pin": {"r":20, "g":19, "b":18 }
		"led2": {
			"pin": {"r":17, "g":24, "b":23 }
	"aliases": {
		"switch": "sw1",
		"button": "sw1",
		"switch1": "sw1",
		"button1": "sw1",
		"switch2": "sw2",
		"button2": "sw2",
		"enp": "encoder_press",
		"switch3": "encoder_press",
		"press": "encoder_press",
		"knob": "knob1",
		"ctrl": "knob1",
		"ctrl1": "knob1",
		"ctrl2": "knob2",
		"led": "led1"
And in your Pure Data patcher, you’ll need a receive object that says “r flex @hv_param” to get the Flex sensor data.
Apologies in advance if this .json file does not work. It’s more for giving you an idea of what it will look like. It should work though but do let me know if I did overlook anything.
Let me know if you have any further questions!!
Wow I just a few minutes ago was reading your youtube comment to me about json files. Here is the info I needed (I think) about how the Daisy Pod is mapped, pots and switches wise.
