I’m really falling at the first hurdle - I’m trying to install the blink example on a Seed without success!
I’m relatively certain I’ve followed the toolchain installation correctly. In VS Code when I try and build the blink example I get this issue:
> Executing task: make <
arm-none-eabi-g++ -c -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard -DSTM32H750xx -ISource -ISource/Control -ISource/Drums -ISource/Dynamics -ISource/Effects -ISource/Filters -ISource/Noise -ISource/PhysicalModeling -ISource/Synthesis -ISource/Utility -O3 -Wall -Werror -fdata-sections -ffunction-sections -MMD -MP -MF"build/adenv.d" -MT"build/adenv.d" -fno-exceptions -finline-functions -std=gnu++14 -static -Wa,-a,-ad,-alms=build/adenv.lst Source/Control/adenv.cpp -o build/adenv.o
Source/Control/adenv.cpp:34:5: internal compiler error: Illegal instruction: 4
34 | x = 1.0f + x / 1024.0f;
Please submit a full bug report,
with preprocessed source if appropriate.
See <https://bugs.linaro.org/> for instructions.
make: *** [build/adenv.o] Error 1
The terminal process "/bin/zsh '-c', 'make'" terminated with exit code: 2.
Any tips?
I forgot to add: I’m on an M1 MacBook Pro macOS 12.4
brbrr
June 22, 2022, 8:34am
#3
What version of arm-none-eabi-g++
you are using? The latest versions, unfortunately, do not support cross-compilation to bare metal from arm64.
GNU Arm Embedded Toolchain 10.3-2021.10 is the latest supported version ATM.
if I check the version it says:
arm-none-eabi-g++ (GNU Toolchain for the Arm Architecture 11.2-2022.02 (arm-11.14)) 11.2.1 20220111
I didn’t really install that one on purpose, I guess it got installed at some point whilst setting up the general toolchain?
so, does that mean I need to change that somehow?
brbrr
June 22, 2022, 9:49am
#5
Yes. you would need to uninstall the version you have right now. I personally was able to set up the toolchain on my M1 by downloading .pkg
from: Downloads | GNU Arm Embedded Toolchain Downloads – Arm Developer
ok cool, I’ll give that a try. I’m a bit concerned that it’s going to be very challenging to uninstall everything correctly! fingers crossed.
success!
I didn’t bother attempting to uninstall the GNU toolchain, I just download the version 10.3 and installed the package and it seems to have overwritten the newer version. I then went back to Visual Studio Code and everything was able to build and install on the Daisy exactly as described in the wiki. Many thanks @brbrr ! I have a blinking LED. time to make some more exciting stuff…
brbrr
June 22, 2022, 1:27pm
#8
cc @shensley since it’s not the first time folks facing issues with toolchain installation on arm64-based (M1) computers. As a quick and dirty solution - the toolchain install script might direct folks to the 10.3 download page with clear messaging on what to do.
Yeah, it is the same for us GNU/Linux users too.
Hi, change the main drive of my laptop and tried to install the toolchain once more (it worked before).
Followed: 1. Setting Up Your Development Environment · electro-smith/DaisyWiki Wiki · GitHub
DL’ed and extracted gcc-arm-11.2-2022.02-x86_64-arm-none-eabi.tar.xz and set the PATH variable.
When I run ./rebuild_all.sh in the DaisyExamples folder I get:
staffan@debiandelle6430:~/Documents/projects/tech/daisy/DaisyExamples$ ./rebuild_all.sh
building libDaisy . . .
In file included from src…
@brbrr @StaffanMelin thanks for the heads up.
I just updated the Mac and Linux installation wikis to have some troubleshooting notes regarding the proper version.
I also updated the relevant links to the same as above (that still points to 10.3) to hopefully avoid other users stumbling into the wrong version in the future.
