Yes, that is the MCU used. But QSPI is a flash storage (with memory mapped access available), not RAM. The external RAM is a normal SDRAM chip. And QSPI is a lot of pain if you want to try to run code from it (instead of the limited amount of 128kb flash), but if your patch is stored on flash it’s not a problem to use QSPI.
Thanks for the info - that’s a HUGE relief - I was getting a bit worried about the QSPI ram (after a brief skirmish with the ESP32 - ha). This really does sound like my dream device. Yeah I can imagine the 128k flash is limiting. I’m just waiting for my stuff to arrive - it’ll be a few weeks I guess (UK) , so I’m doing all the setup ground work and device research - so I can get stuff running quickly!
