Apologies for neo trolling the forum as of late.
I am trying to flash my field from max 8, did the install toolchain and installed the oopsy package trough terminal on the max8 package folder, so install was (i think done properly)
When i load an example patch on max, like the reverb patch, and i choose field and then press the bang i get this errors on the max console
Max Console
gen~: exported: Macintosh HD:/Users/joseluisborrachero/Documents/Max 8/Packages/oopsy/examples/modfm.cpp
oopsy-verbose: script start field 48 /Users/joseluisborrachero/Documents/Max 8/Packages/oopsy/examples/modfm.cpp
oopsy-verbose: stop success dictionary u299000767
oopsy-verbose: start success dictionary u437000768
oopsy-verbose: Target field configured in path /Users/joseluisborrachero/Documents/Max 8/Packages/oopsy/source/daisy.field.json
oopsy-verbose: Building to /Users/joseluisborrachero/Documents/Max 8/Packages/oopsy/source/build_modfm_field
oopsy-verbose: Will upload from /Users/joseluisborrachero/Documents/Max 8/Packages/oopsy/examples/modfm.cpp by writing to:
oopsy-verbose: /Users/joseluisborrachero/Documents/Max 8/Packages/oopsy/source/build_modfm_field/modfm_field.cpp
oopsy-verbose: /Users/joseluisborrachero/Documents/Max 8/Packages/oopsy/source/build_modfm_field/Makefile
oopsy-verbose: /Users/joseluisborrachero/Documents/Max 8/Packages/oopsy/source/build_modfm_field/build/modfm.bin
oopsy-verbose: oopsy generated code
oopsy-verbose: generated code
oopsy-verbose: rm -fR build
oopsy-verbose:
oopsy-verbose: /bin/sh: arm-none-eabi-gcc: command not found
oopsy-verbose: make: *** [build/system_stm32h7xx.o] Error 127
oopsy-verbose: make failed
oopsy-verbose: oopsy done
oopsy-verbose: done
Again apologies for all the troubleshooting!
Many thanks
