Gauging interest in new pedal design
I’ve been working on a new pedal design for the Daisy Seed. I really enjoyed using the Hothouse but wished it had more controls so I built a new pedal design. First and foremost I wanted this for myself but I want to gauge the community’s interest in making this available to a larger audience. I have SMT board and enclosure prototypes made and working. My day job is as a software engineer so writing the firmware was the easiest part for me. It’s based on the format that most of the Daisy hardware drivers use. I’ll open source that when the time comes.
The pedal has lots going on so here are the details.
This design utilizes two boards; one handles the 1/4 jacks, power and audio circuits. The other handles the controls and Daisy. The boards are connected using an IDC connector.
Enclosure
1590XX style enclosure with a matte finish and custom silkscreen.
Knobs
12 16mm alpha pots connected to two CD4051 analog multiplexers. These use the built-in analog control mux driver.
Toggle Switches
6 SPDT Taiway switches connected to two 74HC165 shift registers. These use a custom driver but could probably be contributed upstream if there is interest.
Leds
2 5mm RGB Leds connected to one PCA9685. These use the built-in LED driver.
Footswitches
2 Pro-Grade SPST Momentary Foot Switches (Normally Open, Soft Touch) are wired to the main board using JST connectors.
Input Jacks
2 1/4" switched stereo jacks for separate left and right channels. The ring is connected as a switch and can be used in code to tell if something is plugged into the jack. The switch of each channel’s tip is connected to the other channel so you get an analog signal on the channel that is not connected.
Output Jack
Expression Jack
1 1/4” switched stereo jack for expression input. The tip takes a 3V input and passes it through a buffer before sending it to the Daisy. The ring provides a stable 3V output. You would typically connect the ring and tip to an external expression pedal/pot to control the voltage.
True Bypass
The pedal comes with two relays to provide true bypass of both the left and right channels. When bypassed the input and output jacks are connected directly.
Tails/Trails Bypass
The pedal comes with four analog IC-based switches. These allow you to bypass the buffered signal going into the Daisy for each channel. The other two switches let you bypass the buffered dry signal from mixing with the Daisy’s audio out. Used in tandem, you can have trailing bypass by disabling signal input into Daisy’s audio in and enbling buffered dry output. If you don’t want to mix the dry and wet signals in software this configuration enables mixing the buffered dry signal with the Daisy’s wet output.
If anyone is interested in something like this existing, let me know!
Some interesting ideas here. I’m curious about how the switched jacks are read for detection, and how the relays handle various combinations of input and output jack insertions?
Very cool ideas here. I think you’ll have lots of interest in a project like this…
The switched jacks work like normally closed SPST switches. It’s configured as a POLARITY_NORMAL Switch, so when a jack is inserted the switch reads as pressed. I don’t currently have default handling for the jacks controlling the relays; the user must decide how they want it to work. If it were me, I would make switching between true and tails selectable via one of the toggle switches or implement some fancy startup logic by listening to the footswitch press and saving the setting to ram. The jack switches allow for neat routing without relying on toggle switches. For example you can detect if the user wants mono in/mono out, mono in/stereo out, true stereo, etc. I’ll provide example code for some of these scenarios.
Are the switched jacks read like the toggles (with shift register), or using their own GPIO pins?
Good question. The switch jacks are connected to their own gpio pins. The shift register is only used for the toggle switches.
I have a working prototype assembled! So far so good. I need to finalize the code and some examples but I think it’s pretty close to sharing with y’all.
This is looking awesome!!
Looking great! Very excited to see progress on this!
I just received my Hot House and the Daisy Seed last night. It’s a tad early for me to delve into something that intense-looking, but I could see my playing with it in the future! Great idea! Want to see it unfold.
Hit a snag with some of the switching resulting in annoying pops. No one wants annoying pops! I have another prototype on order but in the meantime I’ve been working on some docs.
Here is a pinout diagram:
Here is a audio flow diagram for the left and right channels:
Wow amazing count me in!
Quick update. I think I have sorted out all the hardware issues that came up in the previous prototypes. I changed the design a bit from what I originally posted. Mainly the way the bypass works has been modified. It now works like a relay bypass with soft muting. I have a software driver for this that handles all the switch timing. I’ve also changed to a single board layout to reduce manufacturing costs.
I’ve published the software for this GitHub - soundreform/dripline · GitHub . It’s still a very much beta but should give you a good idea of how it will work.
Thanks for all that have expressed interest!
