Flashing gets stuck after upgrading to macOS Tahoe 26.0
Hi there,
I recently upgraded to macOS 26.0, and most of the times when I flash my Daisy Patch Rev3 with the STM debug probe the flashing process gets stuck here:
** Programming Started **
Info : Device: STM32H74x/75x
Info : flash size probed value 128k
Info : STM32H7 flash has a single bank
Info : Bank (0) size is 128 kb, base address is 0x08000000
Info : Padding image section 1 at 0x0800e9c4 with 28 bytes (bank write end alignment)
Warn : Adding extra erase range, 0x0800e9e0 .. 0x0801ffff
I am saying most of the times as the issue is not 100% reproductible. As far as I have experienced, I can do a fresh new firmware update upon plugging the Daisy, then if I try to re-build and flash, the process gets stuck.
Unplugging and plugging Daisy back to the computer does not always solve the issue. Sometimes it does, sometimes not and I can’t find a way to properly reproduce the problem.
Did anybody encounter something similar? I did not experience this issue with older macOS but it’s a pain to downgrade.
We haven’t upgraded to Tahoe but can’t imagine how it can mess with flashing to Daisy.
One of the engineers may upgrade soon and see if something similar is encountered.
Was there something else that changed in your setup around the time the upgrade happened?
Probably not this, but maybe:
After reading the comments above and trying to further troubleshoot, I run into another issue - the STLINK was not being seen by my mac. This was not the case when I wrote the original post.
I tried all sorts of toolchain reinstall procedures, macOS update again to Tahoe 26.0.1, USB cable and USB port swaps, and then the STLINK was again seen by the computer.
Then I tried to flash the Daisy and I did not experience any failure. I tried again several times and everything went smoothly. I really cannot tell where the original issue was, but thank you for your support anyway.
I did the update today, just to see if anything new came up. Seems okay to me.
One thing that I have noticed with the Apple silicon Macs, regardless of OS, is that the USB-C ports seem to have extremely finnicky, and inconsistent behavior with the ST-Link Debug probes. In my case, this happens on the ports on the mac, or when using a dock, or other USB-C hubs.
This is observed as either init-failed errors, stalling in the middle of programming, etc. So it’s possible this is what you were running into.
What I have found to be a reliable solution is to use a cheap USB 2.0 hub, and a USB-C to USB-A connector between the ST-Link and the macbook ports. Connected this way, I don’t think I have had any of the reliability issues come back.
Hi there, small update to this topic.
Since the last update to this post, I have been quite digging this forum looking for answers. The issue is persistent in the sense that it is not reproducible 100% of the times.
However:
  • I don’t have the issue when flashing with Windows,
  • I have seen that on my mac M3, when I type file `which openocd` in my Terminal window, this is the output I get: Mach-O 64-bit executable x86_64.
Can this be the main issue? To clarify, I got my openocd with the mac toolchain installer here and I just did a fresh reinstall of the toolchain just before typing this reply.
Could it be that the toolchain installer is not installing the right openocd version for this machine?
[EDIT]
I just replaced the openocd x86 version with an arm64 version taken from here.
I managed to flash easily once, but then the issue persists. Here’s the last bit of the output when running make clean all program
xPack Open On-Chip Debugger 0.12.0+dev-02228-ge5888bda3-dirty (2025-10-04-22:45)
Licensed under GNU GPL v2
For bug reports, read
Warn : DEPRECATED: auto-selecting transport “swd (dapdirect)”. Use ‘transport select swd’ to suppress this message.
Error: libusb_open() failed with LIBUSB_ERROR_OTHER
Error: open failed
** OpenOCD init failed **
shutdown command invoked
embedded:startup.tcl:1893: Error:
File “embedded:startup.tcl”, line 1928, in program
program_error {** OpenOCD init failed **} 1
File “embedded:startup.tcl”, line 1893, in program_error
shutdown error
make: *** [program] Error 1
