I installed the toolchain (used the installer and already had Git installed)
Cloned the source files
I already had VS Code installed but I changed default terminal to Git-Bash
Opened the blink folder
Connected Daisy Seed with USB
Put Daisy into bootloader mode
Tried to run task build_all
Then I ran into an error. In my terminal window in VSC I get the following:
* Executing task: make
mkdir -p build/Drivers/STM32H7xx_HAL_Driver/Src
The syntax of the command is incorrect.
make: *** [Makefile:357: build/Drivers/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal.o] Error 1
* The terminal process "C:\Windows\System32\cmd.exe /d /c make" terminated with exit code: 2.
* Terminal will be reused by tasks, press any key to close it.
and from here I am stuck and can’t do anything else. Any help would be appreciated.
Hey Scott!
I would be happy to look into this with you.
Thank you for confirming that you followed the steps. It sounds like you did everything right.
First possible thing is that you mentioned Git already being installed. It may help to build on the latest version. You can upgrade with git update-git-for-windows.
