Hi everyone !
I just received my Daisy Patch, not a lot of sweat to use and it’s already rewarding !
You guys did a terrific job !
I was curious if it’s possible to display a value on the OLED screen, the obvious idea behind that is debugging. There is a few things that don’t behave as expected in my patch and I would to see what is happening.
Note also – we have a proof of concept working that can stream text out of the daisy over USB back to the host via serial input (receiving via the [serial] object in Max, for example).
This is also something that could be integrated for debugging, if there’s a good idea of what that interface should look like in the gen~ environment – i.e., how you would set up a gen~ patcher (using history or out objects) to specify what data to send.
That looks like a good solution, it will do what I need and solve issue#40 at the same time !
Since I’m really new to MAX, I started to have a look on how to hack the param to do this (since param are displayed on the OLED, if I inject values in a param, it should be displayed…) But after reading the code a little bit, it’s not even close to a solution
Long sentence too say that I would like to contribute, but I’m not ready yet
