'Dirty' signal when viewed through scope
Hi there. Ive got my daisy seed working using the examples output using pins 20(AGND), 19(audio out 2), and 18 (audio out 1) - connected to a 3.5mm jack then into my amp. sounds pretty good but when i view through my scope the signal looks really bad. with one probe on AGND and the other on audio 1 or 2 i can see the waveform but its very distorted. i compared this with my other synths (i have a korg nts 1 which uses a similar MCU) and the signal was much cleaner. whats going on here. is the daisy seed just using a very rudimentary setup. i know its DAC is supposed to be pretty good but the signal says otherwise. i also cant troubleshoot my wave generation if i cant see it properly. any help much appreciated. thanks.
