i tried to upload a patch that exeded the 128kb flash. so i went for the “size” option.
first with plugdata and later with pd2dsyGUI. actually this used to work. later i tried to find its limits with many oscillators etc…
so now its stuck with an old patch. i can flash the bootloader with “size” option. but with “flash program” i allways get the error message:
Flashing Daisy...
Error: Last page at 0x900540f7 is not writeable
This probably means you're attempting
to write Daisy Bootloader programs to the
normal system bootloader (ROM option set to
size). If you want to flash programs to the
Daisy bootloader, ensure that you flash the
bootloader itself first.
and
Device ID 0483:df11
Device DFU version 011a
Claiming USB DFU Interface...
Setting Alternate Interface #0 ...
Determining device status...
DFU state(2) = dfuIDLE, status(0) = No error condition is present
Downloading element to address = 0x90040000, size = 82168
dfu-util: Last page at 0x900540f7 is not writeable
make: *** [../../../../libdaisy/core/Makefile:330: program-dfu] Fehler 64
even if the new patch is using only one phasor~ and dac~.
its like its trying to upload an bigger old cached version.
i reinstalled everthing.
flashing with “speed” option works fine.
i run everthing on arch based linux. and the latest versions.
is there a way to reset / flash the daisy to factory settings ?
and if its about some cached temponary files / settings - where are they located ?
of course i deleted the build files.
just tried it with another machine. so its not about old cached files.
“flash bootloader” option size works.
“flash program” option size fails.
and an old program keeps running after reset.
the old program (?) seem to be persistent in the sram.
what can i do ?
after pd2dsyGUI and plugdata v0.7.1 my test with pd2dsy:
simple phasor~ → dac~ patch
option size
python pd2dsy.py --board pod --rom size ../_patches/again.pd
FLASH: 0 GB 128 KB 0.00%
DTCMRAM: 16772 B 128 KB 12.80%
SRAM: 86268 B 512 KB 16.45%
RAM_D2_DMA: 16704 B 32 KB 50.98%
RAM_D2: 0 GB 256 KB 0.00%
RAM_D3: 0 GB 64 KB 0.00%
ITCMRAM: 0 GB 64 KB 0.00%
SDRAM: 0 GB 64 MB 0.00%
QSPIFLASH: 0 GB 7936 KB 0.00%
Device ID 0483:df11
Downloading element to address = 0x90040000, size = 86268
dfu-util: Last page at 0x900550fb is not writeable
make: *** [../libdaisy/core/Makefile:330: program-dfu] Fehler 64
option double_size
python pd2dsy.py --board pod --rom double_size ../_patches/again.pd
DTCMRAM: 0 GB 128 KB 0.00%
SRAM: 16772 B 512 KB 3.20%
QSPIFLASH: 86268 B 7936 KB 1.06%
Device ID 0483:df11
option speed
python pd2dsy.py --board pod --rom speed ../_patches/again.pd
FLASH: 86440 B 128 KB 65.95%
RAM_D2: 16704 B 288 KB 5.66%
QSPIFLASH: 0 GB 8 MB 0.00%
Device ID 0483:df11
Downloading element to address = 0x08000000, size = 86440
Erase [=========================] 100% 86440 bytes
Erase done.
Download [=========================] 100% 86440 bytes
Download done.
File downloaded successfully
Submitting leave request...
make: *** [../libdaisy/core/Makefile:330: program-dfu] Fehler 74
Hey robotnik!
That third post looks right, but I’ll include this here just in case.
Here are the steps that you can follow to get more comfortable with using the Daisy Bootloader with pd2dsyGUI.
I have set up a sine.pd
(just [osc~ 440]) and phasor.pd
(just [phasor~ 440] like what you have been doing) for testing purpose.
Let’s flash the Daisy Bootloader first.
I’ll set the RAM
to Size
and ROM
to Size
Then, I go through the usual bootloader sequence (press and hold Boot, press and hold Reset, let go of Reset, and let go Boot). After that, click Flash Bootloader
After it’s flashed, you can tell that it worked by observing the LED being in grace mode (a slow fade in and fade out of the Daisy’s on-board LED).
Let’s flash the sine.pd
using the Daisy Bootloader next.
Press and let got the Reset button and then immediately press and let go Boot (in order to extend the grace period) and then click Flash Program
. Now we hear a sine tone beep! And the FLASH
memory usage will be displayed as 0% in the terminal app that should’ve launched when you opened up pd2dsyGUI (and more SRAM
and RAM_D2
are used instead).
Extending the grace period with the Boot press helps.
Let’s also try the phasor.pd
with the Daisy Bootloader.
Follow the same exact step as previous step but with phasor.pd
selected. We should hear a buzz now and confirm that the FLASH
memory usage is 0% again.
Ok, let’s go back to using the FLASH
memory.
Change back the RAM
to Speed
and ROM
to Speed
. Then, I’ll select sine.pd
After going through the usual Bootloader sequence, click on Flash Program
We should hear a beep and then check that the Flash
memory is used (it’s not 0%).
I hope this answers your question!
i am sorry. i messed up the procedure: press and hold boot than reset, releasing reset than boot, press reset and than boot, flash program -oh dear.
so now its working
thank you
No worries at all! It becomes muscle memory eventually.
I’m glad to hear that it’s working
