I recently got Field and ST-Link V3 MINIE.
Seems like I am struggling to connect the debugger.
First of all, when the debugger is connected, I should or should not have the USB connection also or does that matter?
Second of all, could somebody be kind to help me find out where am I making mistake,
here’s my openocd output:
make program
openocd -s /usr/local/share/openocd/scripts -f interface/stlink.cfg -f target/stm32h7x.cfg \
-c "program ./build/Blink.elf verify reset exit"
xPack Open On-Chip Debugger 0.12.0-01004-g9ea7f3d64-dirty (2023-01-30-17:05)
Licensed under GNU GPL v2
For bug reports, read
Info : clock speed 1800 kHz
Info : STLINK V3J8M3 (API v3) VID:PID 0483:3754
Info : Target voltage: 3.203206
Info : [stm32h7x.cpu0] Cortex-M7 r1p1 processor detected
Info : [stm32h7x.cpu0] target has 8 breakpoints, 4 watchpoints
Error: read_memory: read at 0x5c001004 with width=32 and count=1 failed
Error executing event examine-end on target stm32h7x.cpu0:
/usr/local/share/openocd/scripts/target/stm32h7x.cfg:237: Error: read_memory: failed to read memory
in procedure 'program'
in procedure 'stm32h7x_dbgmcu_mmw' called at file "/usr/local/share/openocd/scripts/target/stm32h7x.cfg", line 176
in procedure 'stm32h7x_mmw' called at file "/usr/local/share/openocd/scripts/target/stm32h7x.cfg", line 260
in procedure 'stm32h7x_mrw' called at file "/usr/local/share/openocd/scripts/target/stm32h7x.cfg", line 242
at file "/usr/local/share/openocd/scripts/target/stm32h7x.cfg", line 237
Error: jtag status contains invalid mode value - communication failure
Polling target stm32h7x.cpu0 failed, trying to reexamine
Examination failed, GDB will be halted. Polling again in 100ms
in procedure 'ocd_process_reset'
in procedure 'ocd_process_reset_inner' called at file "embedded:startup.tcl", line 1193
in procedure 'stm32h7x_dbgmcu_mmw' called at file "/usr/local/share/openocd/scripts/target/stm32h7x.cfg", line 170
** Unable to reset target **
Info : Previous state query failed, trying to reconnect
Examination failed, GDB will be halted. Polling again in 300ms
shutdown command invoked
make: *** [program] Error 1
Thanks in advance,
Sina
