I’m using a Daisy Seed and have successfully uploaded the USB_MIDI example via the web programmer. I tested it using MIDI Ox and it all works fine as expected.
I then spent some time setting up Visual Studio + Visual GDB + Segger J-Link EDU mini.
This tutorial was very good, although a few things have changed since it was written. The biggest one is the need to use the Visual_Studio_CleanUp branch of LibDaisy, not the Master.
Eventually I got projects building successfully and uploading. I need to use MIDI over USB for my project, so tested uploading the USB_MIDI example. However when in debug mode I found that the Daisy appeared in device manager with an exclamation mark and “cannot start”. When in release mode the Daisy appears to be working fine in device manager, but when I connected in MIDI Ox I found that MIDI Ox would freeze as soon as any MIDI data was sent to the Daisy. Pressing Reset on the Daisy would unfreeze MIDI Ox, but disconnect it from the Daisy. I also tried other MIDI programs with similar results. As soon as data is sent from the app to the Daisy the app would freeze or MIDI functionality would stop.
Any suggestions how I can start diagnosing what is wrong with the build. Could it be something in the Visual GDB settings?
