Hi there,
I am working on a project which makes use of two codecs. I got an external WM8731 codec board which I want to use with SAI2.
I butchered DaisySeed::ConfigureAudio()
to include SAI2 initialization as per the below:
// Configure
SaiHandle::Config sai_config2;
sai_config2.periph = SaiHandle::Config::Peripheral::SAI_2;
sai_config2.sr = SaiHandle::Config::SampleRate::SAI_48KHZ;
sai_config2.bit_depth = SaiHandle::Config::BitDepth::SAI_24BIT;
sai_config2.a_sync = SaiHandle::Config::Sync::SLAVE;
sai_config2.b_sync = SaiHandle::Config::Sync::MASTER;
sai_config2.pin_config.fs = GetPin(27);
sai_config2.pin_config.mclk = GetPin(24);
sai_config2.pin_config.sck = GetPin(28);
// Data Line Directions
sai_config2.a_dir = SaiHandle::Config::Direction::RECEIVE;
sai_config2.pin_config.sa = GetPin(26);
sai_config2.b_dir = SaiHandle::Config::Direction::TRANSMIT;
sai_config2.pin_config.sb = GetPin(25);
I2CHandle::Config i2c_config;
i2c_config.mode = I2CHandle::Config::Mode::I2C_MASTER;
i2c_config.periph = I2CHandle::Config::Peripheral::I2C_1;
i2c_config.speed = I2CHandle::Config::Speed::I2C_400KHZ;
i2c_config.pin_config.scl = GetPin(11);
i2c_config.pin_config.sda = GetPin(12);
I2CHandle i2c_handle;
i2c_handle.Init(i2c_config);
Wm8731::Config codec_cfg;
codec_cfg.Defaults();
Wm8731 codec;
codec.Init(codec_cfg, i2c_handle);
// Then Initialize
SaiHandle sai_2_handle;
sai_2_handle.Init(sai_config2);
// Audio
AudioHandle::Config audio_config;
audio_config.blocksize = 48;
audio_config.samplerate = SaiHandle::Config::SampleRate::SAI_48KHZ;
audio_config.postgain = 1.f;
audio_handle.Init(audio_config, sai_1_handle, sai_2_handle);
and then I simply write to the desired output streams in the audio callback. While this works, there is a problem related to some audible clicks when outputing a full amplitude sine. You can hear the effect here: https://hq.scene.ro/sai2-sine-output.flac
Am I doing something wrong? Does anybody else have this problem?
Thanks,
benishor
