CV IN and a knob in the same ADC
is it possible to have a CV input jack and a knob controlling the same parameter, both going in the same Analog GPIO pin?
Also, what would happen if I put 0-10v CV from my eurorack system to a Daisy Seed analog input? Will I fry the Seed or it will just stop reading cv once it goes above 5v?
Thank you
Hi mirko!
It’ll be better to have each signal going into its dedicated analog pin separately.
Anything above 3.3 volt will indeed fry the analog input pin. What you could use is zener limiter (Zener Limiters) and/or voltage divider.
There’s also this approach of using op-amp that’s better (Designing Winterbloom's Castor & Pollux - Stargirl (Thea) Flowers in the “Control Voltage Inputs” section)
I thought the normal range which the CVin is able to handle is depending on Negative Power and Positive Power inputs. So it should be able to handle more then 3.3v before it gets fried.
For the Patch SM, what you’re saying is correct from my understanding.
From the Patch SM Data:
Since OP is building a project with the Seed, it’s safe to keep the signal below 3.3V
From the Seed Data:
I actually overlooked this part in the datasheet which explains that most pins on the Seed are actually 5V tolerant (I’m sorry about that).
But there are still pins that are 3.3V tolerant, so it’s good to keep everything between 0.0 to 3.3 volt.
So @mirko, if you’re interested in using CV inputs from eurorack, it might be better for you to use the Patch SM.
Hey Takumi, thanks for tidying things up. I thought the seed and the sm have the same values for that.
So I can use the Daisy Patch or I can copy the Power management and the ADC inputs schematics from the Patch or from here:
https://kxmx-bluemchen.recursinging.com/
Yes, referencing the Daisy Patch schematic and other Seed-powered modules would be a good idea if you’re doing anything with eurorack signal (audio and/or CV). Good luck!
