Hi, I am working with a custom board for Patch_SM and Oopsy. I’m testing with the below minimal JSON in Oopsy and nothing is output on the pins. If I use the default gate out pins, B5 and B6, this code works - so I assume the component defs file is correct for those pins, but not for the peripheral GPIO pins, or the pin mapping is incorrect? Any help much appreciated.
The component defs file for the seed seems to be much further developed. Are there limitations to custom boards with Patch_SM? I see that the SD GPIO pins have external pull-up resistors on the Patch_SM schematic for example. I could swap hardware to the seed, but my application requires the DC coupled outputs of the Patch_SM, the new data sheet for the seed says the outputs are AC coupled, is this due to the change in codec output stage?
"name": "gate_test",
"som": "patch_sm",
"audio": {"channels": 2},
"components": {
"gate_out_1": {
"component": "GateOut",
"pin": "A9",
"display": "",
"is_default": true
"gate_out_2": {
"pin": "A8",
"display": "",
"is_default": true
