I am trying to create a class to store and play a wav file read from an SD card. The wav data is stored on the SDRAM. I had this working with the same code that is in SampleVoice in the main loop and the audio call back using global variables. I’ve seen some posts about FIL fp having to be global and not on the stack but I’ve made SampleVoice sample global.
When I run the code below it returns 1 and seems to be failing on the first read.
Any help would be greatly appreciated pretty stuck on this one.
#include <stdio.h>
#include <string.h>
#include "daisy_seed.h"
#include "sys/fatfs.h"
#include "daisysp.h"
using namespace daisy::seed;
DaisySeed hw;
SdmmcHandler sd;
FatFSInterface fsi;
DIR dir;
FILINFO fil;
Switch play;
class SampleVoice {
private:
uint32_t bufferLength;
size_t length;
size_t position;
bool playing;
int16_t *buffer;
FIL fp;
public:
// buffer should be predefined in SDRAM
void Init(int16_t *buffer, uint32_t bufferLength) {
this->buffer = buffer;
this->bufferLength = bufferLength;
length = 0;
position = 0;
playing = false;
// starts sample playing. need to add handling of sample already playing.
void Play() {
playing = true;
float Stream() {
if (playing) {
if (position >= length) {
playing = false;
position = 0;
return 0;
return s162f(buffer[position++]);
return 0;
/* adds given file to the buffer. Only supports 16bit PCM 48kHz.
* return
* 0: succesful
* 1: file read failed
* 2: invalid format
* 3: file too large
int SetSample(TCHAR *fname) {
UINT bytesread;
WAV_FormatTypeDef wav_data;
if(f_open(&fp, fname, (FA_OPEN_EXISTING | FA_READ)) == FR_OK) {
// Populate the WAV Info
if(f_read(&fp, (void *)&wav_data, sizeof(WAV_FormatTypeDef), &bytesread) != FR_OK) {
return 1;
} else return 1;
if (wav_data.SampleRate != 48000 || wav_data.BitPerSample != 16) return 2;
if (wav_data.SubCHunk2Size > bufferLength) return 3;
if (f_lseek(&fp, sizeof(WAV_FormatTypeDef) + wav_data.SubChunk1Size) != FR_OK) return 1;
if(f_read(&fp, (void *)&buffer, wav_data.SubCHunk2Size, &bytesread) != FR_OK)return 1;
length = wav_data.SubCHunk2Size;
f_close(&fp);
return 0;
bool endsWith(const char *str, const char *suffix);
#define MAX_SAMPLE_LENGTH 4000000
int16_t DSY_SDRAM_BSS sampleBuffer[MAX_SAMPLE_LENGTH];
SampleVoice sample;
play.Debounce();
if (play.RisingEdge()){
hw.PrintLine("Play");
sample.Play();
out[0][i] = sample.Stream()*0.25;
out[1][i] = sample.Stream()*0.25;
play.Init(D29);
hw.StartLog(true);
SdmmcHandler::Config sd_cfg;
sd_cfg.Defaults();
sd_cfg.width = daisy::SdmmcHandler::BusWidth::BITS_4;
sd_cfg.speed = daisy::SdmmcHandler::Speed::FAST;
sd.Init(sd_cfg);
fsi.Init(FatFSInterface::Config::MEDIA_SD);
f_mount(&fsi.GetSDFileSystem(), "/", 1);
f_opendir(&dir, fsi.GetSDPath());
FRESULT result;
while(1) {
result = f_readdir(&dir, &fil);
if (result == F_OK) hw.PrintLine("SD OK");
else hw.PrintLine("SD FAIL");
if (endsWith(fil.fname, ".wav")){
hw.PrintLine("Wav: %s", fil.fname);
break;
f_closedir(&dir);
sample.Init(sampleBuffer, MAX_SAMPLE_LENGTH);
int ret = sample.SetSample(fil.fname);
hw.PrintLine("SetSample return %d", ret);
while(1) {
bool endsWith(const char *str, const char *suffix) {
size_t str_len = strlen(str);
size_t suffix_len = strlen(suffix);
return (str_len >= suffix_len) && (!memcmp(str + str_len - suffix_len, suffix, suffix_len));
Yeah that’s it haha I was too busy checking the code in the class to look at the main loop, well spotted.
Here is the working Class for anyone looking at this thread. Currently works for 16bit PCM at 48KHz. The card must be initialized using f_mount before calling SetSample.
#include <stdio.h>
#include <string.h>
class SampleVoice {
private:
size_t length;
size_t position;
bool playing;
int16_t *buffer;
FIL fp;
bool stereo;
public:
length = 0;
position = 0;
playing = false;
void Play() {
playing = true;
float Stream() {
if (playing) {
playing = false;
position = 0;
return 0.0;
return 0.0;
void SetLength(size_t length) {this->length = length;}
void *GetBuffer() {return (void *)buffer;}
uint32_t GetBufferLength() {return bufferLength;}
bool IsStereo() {return stereo;}
bool IsMono() {return !stereo;}
* If Stereo samples are interleaved left then right.
* return 0: succesful, 1: file read failed, 2: invalid format, 3: file too large
UINT bytesread;
memset(buffer, 0, bufferLength);
if(f_read(&fp, (void *)&wav_data, sizeof(WAV_FormatTypeDef), &bytesread) != FR_OK) return 1;
} else return 1;
if (wav_data.SubCHunk2Size > bufferLength || wav_data.NbrChannels > 2) return 3;
stereo = wav_data.NbrChannels == 2;
if (f_lseek(&fp, sizeof(WAV_FormatTypeDef)) != FR_OK) return 1;
if(f_read(&fp, buffer, wav_data.SubCHunk2Size, &bytesread) != FR_OK)return 1;
length = bytesread / (wav_data.BitPerSample/8);
f_close(&fp);
return 0;
@hajaba Hey I tried this code and it worked but not for any amount from the wav more than 16384 bytes into the SDRAM buffer (or somewhere between that and 8167 bytes) any thoughts? Other special things you did with SDRAM besides mount it? My SDRAM buffer is much larger than 16384 bytes (its the entire 64 MB)
turns out there were issues with using an SD card through jumper cables on breadboard and had to enable slow mode with sd_cfg.speed = daisy::SdmmcHandler::Speed::SLOW; and then it works with the caveat that writing TO the SD card now creates artifacts. Can’t have it both ways unfortunately until I commit to a PCB order
Hi! I’m trying to get a (looping) WAVPlayer working myself. Tried the code hajaba shared, and this does load a WAV file, as opposed to the daisy-provided WavPlayer with latest libDaisy. However, my (verified 48k, 16bit) WAV files are loaded incorrectly. I get this loaded when I use breakpoints to inspect;
NbrChannels = 27… Should be 1 in my case (trying mono for now).
Any idea why my WAV file would load this strange?
Every WAV I load gives a different number of channels and other values. Seems like the WAV files are being misinterpreted. They play fine on my computer, and played with Daisy WavPlayer before.
I had to make some modifications to the code you shared to get it working in my project. Maybe I broke something. If sharing code would help, just let me know.
Any help would be greatly appreciated!
