No need to apologize! ![]()
They are to protect the Seed from over-voltage. See:
I only use this as I connect external stuff too.
If you are going to connect 2 seeds and only use “internal” connections, there is no need for this. You can use any cable/wire. But you also have to connect ground between the two (so they share it).
