Just a quick check: If I already have a program running with APP_TYPE = BOOT_SRAM, do I have to just change to BOOT_QSPI and flash noramlly? or should I flash the bootloader and than change to QSPI like here: Problems loading in SRAM or QSPI
thanks.
thanks.
If you are using BOOT_SRAM then you are already using the bootloader.
I assume you’ve already read libDaisy/doc/md/_a7_Getting-Started-Daisy-Bootloader.md at master · electro-smith/libDaisy · GitHub ?
