Hi!
I’m trying to figure out what is the correct setup for my application.
In the DSP chain that I’m currently working on there is a need for input and output FIR filters of 10ms.
In the term of samples, it would be 480 samples for the 48kHz sample rate.
Should I increase the default block size? Or maybe I can somehow use the 2 additional delay lines of the size of a filter and keep the default block size to reduce latency?
