Hi !
I faced the same question few times ago and the solution found is to modify libdaisy code :
// file : libdaisy/src/usbd/usbd_desc.c
// line 77 :
#define USBD_PRODUCT_STRING_FS "Daisy Seed Built In"
I’ve replaced this line with
extern const char* USBD_PRODUCT_STRING_FS;
So you just have to add a definition for this variable somewhere in your code, like in your main cpp file
// file your_main.cpp
const char* USBD_PRODUCT_STRING_FS = "My custom name";
Works with ALSA and JACK on linux, didn’t tried other os.
You can also just edit the original defined value, but it will be painfull if you’re working on several devices
