Hey everyone. I have created a simple sketch to light up an LED on my neotrellis 4x4 board. Here is the snippet:
#include "daisy_seed.h"
#include "dev/neotrellis.h"
DaisySeed hardware;
auto main() -> int
// Required hw initialization
hardware.Init();
// ---------- INITIALIZE NEOPIXELS ----------------------
NeoTrellisI2C neotrellis;
NeoTrellisI2C::Config neotrellis_config;
neotrellis.Init(neotrellis_config);
neotrellis.pixels.SetPixelColor(0, 255, 0, 0);
neotrellis.pixels.SetBrightness(255);
neotrellis.pixels.Show();
// main loop
while(true)
return 0;
However, when I run it nothing happens. Moreover, when I try to debug calls to SetPixelColor, SetBrightness or Show I can’t, seems like they get optimized away by the compiler for some reason.
Can you please tell me what is wrong with this code?
Bonus question: whenever I launched the debugger before, I would always land on the first function call hardware.init() because there is a flag in the debug task "runToEntryPoint", however, now, without me changing anything (at least conciously) every time I start debugging it jumps to a seemingly random place which is startup_stm32h750xx.c line 1544 do you have any idea what might be the cause of that?
Is this a snippet, or is it a complete program which can be built and run?
With rare exception, it’s best to post a complete example which demonstrates the problem you’re having.
This is a complete program. It is supposed to light up first pixel of a neo trellis board red.
About the optimizing away part of my question, I actually figured it out. It is due to the fact that all those functions are inline. So, changing the optimization flag to -O0 helped with that. However, I still don’t understand why is there no output from the board.
I connected it to the arduino uno and ran a simple example from the adafruit library and everything worked there, and by looking at the code there I see the same functions being called, so not really sure what is the problem.
Interesting - I’ve been meaning to pick up some neotrellis…
Hmmm, what about the I2C? on the correct pins? pullups? which Daisy - Seed?
Hey, it’s working. Turns out I managed to damage the board somehow between unplugging it from Arduino and plugging it to Daisy
idk how that happenned, but I wasn’t able to get the example from arduino running on it again either. I have a spare one and when I plugged it in it worked right away. Just to be clear, here’s a kinda “hello world” project for neotrellis. It sets the first pixel on the board to red
DaisySeed hardware;
auto main() -> int
hardware.Init();
neotrellis.pixels.SetPixelColor(0, 0, 0, 0);
while(true)
return 0;
Excellent! It’s always good to have spares for verification.
I am trying to run this example but no output. The board works with Arduino.
Can you guys share more details on this specific daisy seed setup (pinout, compiler settings etc)? Thanks
