Probably user error, but cant figure out how to get an led light up
A rgb led is connected with its pins to: - to ground, R to D9, G to D10, B to D11
(currently no resistors inbetween as didnt order any and just wanna try making it work, so even if it’ll burn out, it’d be a success)
At start of file
RgbLed led;
In main() (also tried polarity on false)
led.Init(D9, D10, D11, true);
in for loop in main()
led.Update();
on button press
led.Set(0.5, 0.5, 0.5);
is anything with this wrong/missing?
or do we have a hardware issue?
or?
didnt know there exists a common anode version
will try that out when back at the workbench
do we see that right, that we can leave blue and green without a resistor, as their max voltage is 3.6V and only need one for red with its max voltage of 2.4V?
EDIT: whats the difference between 3.3V analog and 3.3V digital?
Im pretty sure you can use either common anode or common cathode, that’s the purpose of the polarity in Init().
For common cathode, the long leg (cathode) goes to ground. For common anode, the long leg (anode) goes to +3.3.
You could test this using an ordinary LED.
