I’ve been having fun with my seed, and hooked it up to my eurorack using the awesome Loewenzahnhonig. Dabbling in code and the examples and flashing a series of different things. So far, the setup guides have been very thorough and helpful.
The thing I can’t figure out though is the classes I am missing for some of the examples. For instance, the ReverbSc example or MoogLadder don’t work. When the classes are used to declare the variables there’s a red squiggly line. I read some things on the forums how this may have to do with the DaisySP_LGPL but I’m not sure how to resolve that.
Right, that’s indeed the thread I found. However, these seed dsp examples already have that line in their makefile. Is there an extra ‘task’ I need to run or variable that needs to point to this LGPL library?
I forgot, you’re using VS Code- there might be an extra step required to get that working. I don’t use VS Code, so I don’t know the answer, but I know others have had that problem.
Thanks @tele_player . This at least got me looking in the right direction. It definitely has to do with LGPL libraries not being linked properly. Maybe VSCode is more strict than other IDE’s, I dunno? I have a workaround by changing the daisysp.h file directly, but I’m not sure what knock on effects that may have. I’m working on Windows, VSCode, Seed, and am not using the “cortex debug” or ST-link
Step 1 daisysp.h comment out line 92 #ifdev USE_DAISYSP_LGPL and its #endif.
This will allow me to use MoogLadder and ReverbSc as recognized types in the IDE, but builds will fail because of not finding the daisysp-lgpl.h file
Step2 daisysp.h change line 93 to #include “…/DaisySP-LGPL/Source/daisysp-lgpl.h”
This links to the correct header file in the right folder. On build it will now use the lgpl and run into a problem there.
Step3 daisysp-lgpl.h comment out line 29 for the PolyPluck.h
The file seems to be in that folder without a cpp file. Did not investigate further.
Now the build and flash work properly, and I seem to be able to use the LGPL classes.
@Takumi_Ogata, let me know when fixes are in place and I will get a fresh clone and test to verify. The overall getting started explanations have been great up until writing and flashing my own firmware without LGPL, but afterwards testing ReverbSc, Moogladder or Osc have been a let-down. Let’s fix this before the next new user comes in
The intellisense engine doesn’t know about the makefile, so this tells it to consider that preprocessor definition defined when indexing the code. That should make the squigglies go away. I bet this was just missed when DaisyExamples was updated for the DaisySp LGPL split.
Just a bump to say that this issue is still extent. Tried all the suggestions and moogLadder is still not known in VSCode and does not compile in that environment. It does compile from the command line.
Thank you - I could have sworn that I tried that after reading your earlier comment, but I tried it again and this time it works. Thanks again. Is there some other issue that is causing the need to add the extra include ?
i am having issues like this, i can not access any of the effects in the LGPL folder. even after adding the recommended USE_DAISYSP_LGPL=1. any good solution that doesnt require me to edit too much core daisysp or libdaisy files?
hmmm it looks like maybe something is wrong with the intellisense not recognizsing certain things. when i type for instance:
Compressor comp;
at the top of my line to use the compressor it remains white (except comp turns blue). this led me to believe it didnt work, but also the members don’t automatically show when i type comp. which i use a lot to not have to refer to the documentation all the time to find out what it does.
but when i define it like that and flash it it works so, no error.
no idea why it doesnt recognize it anymore though. have to find out why intellisense doesnt pick up on it.
