** EDIT: SEE UPDATE BELOW**
Hi folks,
I’m attempting to use the new (unreleased) daisy bootloader_v6 to install a program to SRAM on my Patch by following this guide. The program loads and runs, but does not work once I unplug seed from my computer and reboot it.
I’ve done the following steps:
Setup:
- Checkout the “bootloader_v6” branch in libDaisy, and the latest master branch in DaisySP. Copy those folders into my project root directory (clone of daisy-projects).
- Run
rebuild_all.shfrom the root directory to build libDaisy and DaisySP. - hold the
bootbutton on seed, press theresetbutton, releasebootto put Daisy in DFU mode - Go to project directory.
make program-bootto install the bootloader - Add
APP_TYPE = BOOT_SRAMto my project makefile
Installing the binary
- Build the program:
make clean; make - Plug a USB from my computer into seed’s USB port. This will power seed on.
- Press seed’s
bootbutton immediately to extend the bootloader “grace period”. It will confirm by blinking the LED rapidly. - Write the program to seed:
make program-dfu. Program appears to write successfully. Output shows that program resides in SRAM:
FLASH: 0 GB 128 KB 0.00%
DTCMRAM: 16356 B 128 KB 12.48%
SRAM: 131020 B 480 KB 26.66%
RAM_D2_DMA: 16968 B 32 KB 51.78%
RAM_D2: 0 GB 256 KB 0.00%
RAM_D3: 0 GB 64 KB 0.00%
BACKUP_SRAM: 12 B 4 KB 0.29%
ITCMRAM: 0 GB 64 KB 0.00%
SDRAM: 645716 B 64 MB 0.96%
QSPIFLASH: 92 B 7936 KB 0.00%
arm-none-eabi-objcopy -O ihex build/Musubi.elf build/Musubi.hex
arm-none-eabi-objcopy -O binary -S build/Musubi.elf build/Musubi.bin
dfu-util -a 0 -s 0x90040000:leave -D build/Musubi.bin -d ,0483:df11
dfu-util 0.10
ID 0483:df11
Claiming USB DFU Interface...
dfuIDLE, continuing
Device returned transfer size 4096
DfuSe interface name: "Flash "
Downloading element to address = 0x90040000, size = 131020
Erase [=========================] 100% 131020 bytes
Erase done.
Download [=========================] 100% 131020 bytes
Download done.
File downloaded successfully
Transitioning to dfuMANIFEST state
Observed behavior: The program runs as expected. However, once I disconnect the USB and reboot patch, the OLED screen is blank. The LED on seed repeatedly blinks in cycles of 2-3 slow blinks followed by 8-10 fast ones (the documentation says it would blink “SOS” if there were an error).
Any idea what the issue might be? It’s strange to me because the program successfully boots and runs immediately after it’s installed, but after I remove the USB connection and reboot, bootloader seems to not boot the program.
