I tried to create the object [r Knob1 @hv_param .5 0 1] in Pure Data but the potentiometer doesn’t work. During the conversion this error comes up:
Converting volume3 for pod platform
- e[91mErrore[0m pd2hv: [r Knob1 @hv_param 0.5 0 1] in “volume3.pd” @ (x:158, y:90): Default parameter value is greater than the maximum. Receiver will not be exported: 1 > 0
the correct way to write the object is this: [r Knob1 @hv_param 0 1 0.5] the first 2 values represent the interval and the third the default value.
There’s another problem. It seems the range of values is not working. If I type the object in this way [r Knob1 @hv_param 0 10 5], the range I find is still between 0 and 1.
What can it depend on?
