Hello !
I’m starting an embeded project with the Daisy Seed, and so, it make me look at the DaisySP library. I have two main questions about the biquad class :
As far as I have seen, it is not possible to provide the class with the coefficient directly. It is only possible to provide a frequency and a resonance. This seems very limiting, because, AFAIK, we can’t change the filter type, nor using the biquad class for more “exotic” type of filter. Wouldn’t it better to have a more generic class, where we can simply provide the 5 biquad coefficient, and have a helper function that generate the coefficients, depending on a cut off frequency, a Q factor and a filter type ?
The process function seems to implement the Direct Form I, directly adapted from the difference equation. If I remember correclty, it is not the common to have this form implemented, as it is use more memory and is prone to computation error. Wouldn’t it be better to have the Direct Form II Transposed implemented, with maybe a fall back to a non transposed form for architecture that don’t use floating point numbers ?
I would be more than happy to have some insight about this choice of implementation !
Thank you !
Jean-Loup
