I’m looking for a basic digital delay for the Noise Engineering Versio hardware. They have some great reverbs and a fun multitap delay, but nothing basic. Essentially, I’d like to have the Chronoblob 2, but in Versio format.
Any ideas?
Any ideas?
This would be verrrry easy to implement with Oopsy~
What do you envision the knobs and cv doing?
And what about the switches?
With Oopsy/gen~ you’d want to start with playing with the gen~ [delay] object. Normally this can use delay times measured in samples, so you’ll want to use the [samplerate] object or [mstosamps] to compute what you need.
You can use two [delay] objects for stereo, or just set the 3rd argument to 2 to make a 2-tap delay.
Feedback just means routing the delay output back to the input, which is possible if the [delay] operator has @feedback 1 option set. Probably you want to do this via some kind of filter – there’s lots of gen~ filter code examples that come with Max, or on the c74 forums etc.
Ping pong means flipping the feedback paths between the two delays. Try doing this via a pair of [mix] ops for variable pingponginess.
For clock sync delay times you’ll need to measure the time between incoming clock pulses; a [+], [history], [switch] and [latch] will get you there. Then multiply/divide this by an integer to get clock divisions.
There’s lots more you can do of course, and there’s other stranger stuff like granular and pitch/time shifting etc. if you work with a [data] object instead of a [delay] – again, tons of example patches with Max & on the web.
Daisy is perfect for making these kinds of modules, with absolutely huge amounts of memory for long delay times.
