Before i commit to getting new PCBs made i just want to make absolutely sure i’m not doing anything stupid here. Are the pins used here on the Daisy all ok?
Thanks
Thanks
Just audio in/out, leds, pots, and switches right? Seems fine to me: digital pins for LEDs and switches, analog pins (adcs) for pots.
You’ve probably looked at this pinout document where you can check all the functions and capabilities of a pin. Pretty hard to not hit a digtal pin (blue D pins) and you may not have noticed that there are more adcs available than can be seen on the symbol (pins 29-32 + 35 in addition to the six noted on the symbol). At least those were a few of the minor revelations I had when I took a good look at the pinout pdf.
And, of course, always do a minimum quantity test pcb run before doing any volume! But what you’ve shown looks to be by the book to me. Doesn’t hurt to breadboard the gist of what you have and have a working protoboard to give your designs/schematic confidence too.
Great, thank you for the reply. Fingers crossed the prototype boards work!
