For context, I’m doing my development on Linux with an stlink-v3mini.
Here’s what I did to get it (mostly) working.
Install pyOCD - follow the destructions on GitHub - pyocd/pyOCD: Open source Python library for programming and debugging Arm Cortex-M microcontrollers
I cloned the repo and installed it locally to get recent developments - don’t know how necessary that is.
python3 setup.py install --user
Next step is to get some packs to support it:
pyocd pack -u ;# to update the pack list
pyocd pack -f ;# to see what’s available
pyocd pack -i ;# to install
In this case -
pyocd pack -i STM32H750IBKx
Make a pyocd_user.py - I’m not sure this is the right way to do things - beware…
This file has to go into the dir that your run pyocd/gdb from
The main purpose is to tell pyocd how to write to the onchip flash:
# For Daisy Seed
def will_connect(board):
# For STM32H750xB devices: a 128-Kbyte user Flash memory block containing one
# user sector of 128 Kbytes (4 K Flash words).
# /data/daisy/cmsis/CMSIS/Flash/STM32H7xx_CM7.FLM
flash = pyocd.core.memory_map.FlashRegion(
name="flash",
start=0x08000000,
length=0x20000,
blocksize=0x100,
flm="/data/daisy/cmsis/CMSIS/Flash/STM32H7xx_CM7.FLM"
target.memory_map.add_region(flash)
# Create the DTCMRAM region
dtcmram = pyocd.core.memory_map.RamRegion(
name="dtcram",
start=0x20000000,
length=0x20000
# Add the SDRAM region to the memory map.
target.memory_map.add_region(dtcmram)
# Create the new 64M SDRAM region
sdram = pyocd.core.memory_map.RamRegion(
name="sdram",
start=0xc0000000,
length=0x4000000
target.memory_map.add_region(sdram)
# Create QSPIFLASH - took blocksize from libdaisy/src/per/qspi.c
# TODO: No ALGO for this - can't keep code in it yet
qspiflash = pyocd.core.memory_map.FlashRegion(
name="qspiflash",
start=0x90000000,
length=0x800000,
blocksize=0x1000
target.memory_map.add_region(qspiflash)
# Don't know if this is 100% needed
# The DBGMCU registers are not reset by a system reset, only by a power on reset. They are
# accessible to the debugger via the APB-D bus at base address 0xE00E1000. They are also
# accessible by the processor core at base address 0x5C001000.
# Note: the DBGMCU is not a standard CoreSight component. Therefore, it does not appear
# in the system ROM table.
# DBGMCU configuration register (DBGMCU_CR)
# Address offset: 0x004
# Reset value: 0x0000 0000
# See also CMSIS/Debug/STM32H742_743_753_750.dbgconf
DBGMCU_CR = 0xE00E1004
DBGMCU_APB3FZ1 = 0xE00E1034
DBGMCU_APB1LFZ1 = 0xE00E103C
DBGMCU_APB2FZ1 = 0xE00E104C
DBGMCU_APB4FZ1 = 0xE00E1054
def did_reset():
# Set STANDBY, STOP, and SLEEP bits all to 1.
LOG.info("Setting DBGMCU_CR to 0x7 after reset")
target.write32(DBGMCU_CR, 0x7)
target.write32(DBGMCU_APB3FZ1, 0x0)
target.write32(DBGMCU_APB1LFZ1, 0x0)
target.write32(DBGMCU_APB2FZ1, 0x0)
target.write32(DBGMCU_APB4FZ1, 0x0)
The FLM file mentioned in there is extracted from the previously installed cmsis pack.
I’ll try and get in touch with the pyocd folks to see if it’s the “right thing to do”.
To flash your code:
pyocd flash --target stm32h750ibkx <elf|bin>
In one window:
pyocd gdbserver --target stm32h750ibkx
In another:
arm-none-eabi-gdb
I put this in a .gdbinit file to connect:
target extended localhost:3333
monitor reset halt
info variables
I haven’t figured out how to load updated binaries from gdb yet - working on that.
But I have been able to do some basic debugging this way - setting break points, looking at variables, stepping through code etc.
Good luck.
