thank you teleplayer,
taking you by the word,
here is the code, you can copy it into the oscillator example and build it.
the lfo sweeps the osc frequency and produces horrible aliasing,
the only code involved is the mod matrix(doing nothing), lfo and osc.
if you delete the mod matrix, aliasing is gone:
#include "daisysp.h"
#include <vector>
#include <string.h>
#include "daisy_seed.h"
#include "Utility/dsp.h"
DaisySeed hw;
Encoder encoder;
Switch button;
static Oscillator osc;
static Oscillator osc2;
static Oscillator lfo;
static Svf filt;
static Svf dFilt;
static Metro seqclk;
static Adsr env;
static Adsr envM;
float envout=0, sig=0;
float oscF=24, osc2F=24, osc2seq=0, Cut=0, peak=0;
float seqF=0;
float seqPeak=0;
float seqDec = 0;
int trig=0, trigo = 0, trigA=0, trigB=0;
int Mod1Source=0, Mod1Targ=0, Mod2Source, Mod2Targ=0, Mod3Source=0, Mod3Targ=0, Mod4Source, Mod4Targ=0;
float CutMod=0, PeakMod=0, ResMod=0, WavMod=0, PwMod=0, F1Mod=0, F2Mod=0, OctMod=0, GlideMod=0, LfoFmod=0, LfoAmod=0, TimeMod=0, fbMod=0, colMod=0, dResMod=0, dlvMod=0, AMod=0, DMod=0, SMod=0, RMod=0,
Cut2Mod=0, Peak2Mod=0, Res2Mod=0, Wav2Mod=0, Pw2Mod=0, F12Mod=0, F22Mod=0, Oct2Mod=0, Glide2Mod=0, Lfo2Fmod=0, Lfo2Amod=0, Time2Mod=0, fb2Mod=0, col2Mod=0, dRes2Mod=0, dlv2Mod=0, A2Mod=0, D2Mod=0, S2Mod=0, R2Mod=0,
Cut3Mod=0, Peak3Mod=0, Res3Mod=0, Wav3Mod=0, Pw3Mod=0, F13Mod=0, F23Mod=0, Oct3Mod=0, Glide3Mod=0, Lfo3Fmod=0, Lfo3Amod=0, Time3Mod=0, fb3Mod=0, col3Mod=0, dRes3Mod=0, dlv3Mod=0, A3Mod=0, D3Mod=0, S3Mod=0, R3Mod=0,
Cut4Mod=0, Peak4Mod=0, Res4Mod=0, Wav4Mod=0, Pw4Mod=0, F14Mod=0, F24Mod=0, Oct4Mod=0, Glide4Mod=0, Lfo4Fmod=0, Lfo4Amod=0, Time4Mod=0, fb4Mod=0, col4Mod=0, dRes4Mod=0, dlv4Mod=0, A4Mod=0, D4Mod=0, S4Mod=0, R4Mod=0, Mod1Amt=0, delTfone=.5, delT=.5, dCut=1500, dCtf=5, fb=.5, dlv=.5;
float keyF=0, oct=0;
int beat[8] {1, 1, 1, 1, 1, 1, 1, 1};
int seqP[8] {0, 0, 0, 0, 0, 0, 0, 0};
float seqD[8] {0, 0, 0, 0, 0, 0, 0, 0};
float seDc[8] {0, 0, 0, 0, 0, 0, 0, 0};
int Pval=0, Pval2=0, Pval3=0;
int cnt = 0, step = 0, stepped = 0, steppedO = 0, stepO=0, osc2pv=0;
int pg=0, pg4=0, pgtrig=0, pgtrigO=0;
int Mod4Amt=0, Mod3Amt=0, Mod2Amt=0;
int subP=0, subP4=0, subP3=0, subP5=0;
float lfoF=0, lfo_=0, lfoF_=0, lfoOut=0,lfoFA=0, lfoFB=0, lfoFfn=0, deltalfoF= lfoFA - lfoFB;
int gate_=0, gate=0, scale=0;
int current_preset=0;
float Clfo=0, fPeak=0, Res=0;
float Att=0, dec=0, sus=0, deltasus=0, sus_=0, sus__=0, rel=0;
float AttM=0, decM1=0, susM=0, relM=0;
float lfoP=0, lfoAmpp=0, lfoAmp =0;
float oscFk=0, oscF2k=0;
float wav=0, octi=0;
float pwk=0, pwmk=0;
int cntO=0, ArpOn=0, ArpDir=0;
int pgO=0, btnUp=0, btnDw=0, btnUpO=0, btnDwO=0, btnUproc=0, btnDproc=0, btnL=0, btnR=0, btnLO=0, btnRO=0, btnLproc=0, btnRproc=0, pgtrig2O, pgtrig2;
float fbFin=0, finF1=0, pwm=0, finalF1=0, finalF2=0, lfopamt=0, lfopwamt=0, resFin=0, lfoamt=0, cutFin=0, Menv=0, finF2=0, none=0, finsig=0, glide=0, glidefn=0, finF11=0, finF12=0;
int Filterchoice=0;
int output_value = 0;
int arpmem2=0, arpmem=0;
float my1[8]={0}, my2[8]={0}, my3[8]={0};
float my1_[8]={0}, my2_[8]={0}, my3_[8]={0};
float my1delta[8]={0}, my2delta[8], my3delta[8]={0};
float myP[8]={0}, myP2[8]={0}, myP3[8]={0};
int Major[7]{0,2,4,5,7,9,11};
int Minor[7]{0,2,3,5,8,9,10};
int Penta[5]{0,3,5,8,10};
int keyFsc=0;
int keysc=0;
int scoct=0;
size_t size)
//MODARRAY
//MODARRAY
float Mod1Sources[11]={0, env.Process(trig&&gate_), envM.Process(trig&&gate_), lfoOut, seqDec, seqPeak, seqF, osc.Process(), osc2.Process(), keyF };
float* Mod1Targets[21]={0, &CutMod, &PeakMod, &ResMod, &WavMod, &PwMod, &F1Mod, &F2Mod, &OctMod, &GlideMod, &LfoFmod, &LfoAmod, &TimeMod, &fbMod, &colMod, &dResMod, &dlvMod, &AMod, &DMod, &SMod, &RMod};
for(int i=0; i<21; i++)
{*Mod1Targets[i] = 0;}
*Mod1Targets[Mod1Targ] = Mod1Sources[Mod1Source]*Mod1Amt/24;
float Mod2Sources[11]={0, env.Process(trig&&gate_), envM.Process(trig&&gate_), lfoOut, seqDec, seqPeak, seqF, osc.Process(), osc2.Process(), keyF };
float* Mod2Targets[21]={0, &Cut2Mod, &Peak2Mod, &Res2Mod, &Wav2Mod, &Pw2Mod, &F12Mod, &F22Mod, &Oct2Mod, &Glide2Mod, &Lfo2Fmod, &Lfo2Amod, &Time2Mod, &fb2Mod, &col2Mod, &dRes2Mod, &dlv2Mod, &A2Mod, &D2Mod, &S2Mod, &R2Mod};
{*Mod2Targets[i] = 0;}
*Mod2Targets[Mod2Targ] = Mod2Sources[Mod2Source]*Mod2Amt/24;
float Mod3Sources[11]={0, env.Process(trig&&gate_), envM.Process(trig&&gate_), lfoOut, seqDec, seqPeak, seqF, osc.Process(), osc2.Process(), keyF };
float* Mod3Targets[21]={0, &Cut3Mod, &Peak3Mod, &Res3Mod, &Wav3Mod, &Pw3Mod, &F13Mod, &F23Mod, &Oct3Mod, &Glide3Mod, &Lfo3Fmod, &Lfo3Amod, &Time3Mod, &fb3Mod, &col3Mod, &dRes3Mod, &dlv3Mod, &A3Mod, &D3Mod, &S3Mod, &R3Mod};
{*Mod3Targets[i] = 0;}
*Mod3Targets[Mod3Targ] = Mod3Sources[Mod3Source]*Mod3Amt/24;
float Mod4Sources[11]={0, env.Process(trig&&gate_), envM.Process(trig&&gate_), lfoOut, seqDec, seqPeak, seqF, osc.Process(), osc2.Process(), keyF };
float* Mod4Targets[21]={0, &Cut4Mod, &Peak4Mod, &Res4Mod, &Wav4Mod, &Pw4Mod, &F14Mod, &F24Mod, &Oct4Mod, &Glide4Mod, &Lfo4Fmod, &Lfo4Amod, &Time4Mod, &fb4Mod, &col4Mod, &dRes4Mod, &dlv4Mod, &A4Mod, &D4Mod, &S4Mod, &R4Mod};
{*Mod4Targets[i] = 0;}
*Mod4Targets[Mod4Targ] = Mod4Sources[Mod4Source]*Mod4Amt/24;
osc.SetFreq(lfo.Process()*12000+6000);
finsig=osc.Process();
out[0][i]=finsig*.7f;
out[1][i]=finsig*.7f;
hw.Configure();
hw.Init(true);
hw.SetAudioBlockSize(4);
//hw.SetAudioSampleRate(SaiHandle::Config::SampleRate::SAI_96KHZ);
float sample_rate = hw.AudioSampleRate();
lfo.Init(sample_rate);
//init metro object
seqclk.Init(2, sample_rate);
seqclk.SetFreq (200);
//Set envelope parameters
env.Init(sample_rate);
env.SetTime(ADSR_SEG_ATTACK, .1);
env.SetTime(ADSR_SEG_DECAY, .5);
env.SetTime(ADSR_SEG_RELEASE, .5);
env.SetSustainLevel(.5);
//Mod>Env Init
envM.Init(sample_rate);
envM.SetTime(ADSR_SEG_ATTACK, .1);
envM.SetTime(ADSR_SEG_DECAY, .5);
envM.SetTime(ADSR_SEG_RELEASE, .5);
envM.SetSustainLevel(.5);
osc.Init(sample_rate);
osc.SetWaveform(6);
osc.SetFreq(6220);
osc.SetAmp(0.5);
osc2.Init(sample_rate);
osc2.SetWaveform(6);
osc2.SetFreq(6220);
osc2.SetAmp(0.5);
lfo.SetWaveform(0);
lfo.SetFreq(.2);
// Initialize Filter, and set parameters.
filt.Init(sample_rate);
filt.SetFreq(9500.0);
filt.SetRes(0.1);
filt.SetDrive(0.8);
dFilt.Init(sample_rate);
dFilt.SetFreq(1500);
dFilt.SetRes(0.1);
dFilt.SetDrive(0.1);
/** Initialize our Encoder */
encoder.Init(seed::D6, seed::D7, seed::D8);
// start callback
hw.StartAudio(AudioCallback);
// Setup to print
hw.StartLog();
while(1) {
