I have receive my new board with 32 potentiometers/16 Push buttons/16 Leds and a nextion screen and a Daisy seed of course.
I have test the ADC on my board, but the ADC always return 32768. The analog values are correct on the 4 analog pins ADC0/ADC1/ADC2/ADC3.
So i have try whith a breadboard and a potentiometer…same thing.
I have also try with directl a short cut between the ground and the ADC0 pin…same result
I really do not understand, maybe something around the DMA for the ADC or a bad building for the daisylib…
I use Visual studio code.
The code is
Blockquote
#include “daisy_seed.h”
DaisySeed hardware;
hardware.Configure();
hardware.Init();
hardware.StartLog();
Led led1;
led1.Init(hardware.GetPin(28), false);
AdcChannelConfig adcConfig;
adcConfig.InitSingle(seed::A0);
hardware.adc.Init(&adcConfig, 1);
hardware.adc.Start();
for(;;)
uint16_t val=hardware.adc.Get(0);
hardware.PrintLine("Val %d\r\n",val);
System::Delay(500);
Blockquote
Hi Gilles!
Is this a custom board that you have made? And it sounds like you are using a multiplexer since you have 32 potentiometers.
I would like to know more about which ADC pins are only returning 32768 (interesting that it’s half of the max value of 65536/3.3volt). It sounds like ADC 0 through 3 are working as expected? But in your code it’s using ADC 0 only.
Let’s test this with just the Daisy Seed on a breadboard with a potentiomter connected to ADC0. Your current code looks fine for this testing (by the way, this page is a good reference: libDaisy: Getting Started - ADCs).
With that setup, could you test the ADC read again?
And please do make sure that you have the AGND and DGND connected together on your breadboard.
Thank a lot Takumi for your helpfull and quick support.
In fact i have already done the first part…breadboard + pot or only breadboard…
But the answer was at the end…
So i have connected the 2 gnd on my board and now it ok
Thx again
Glad to hear that it works now!!
