OscPocketD - Portable music tool (sequencing drums and synths)
Hi all,
I’ve played with the Daisy Seed for 2 days and it is great fun! My latest synthesizer projects have been using Arduino with the excellent Mozzi library and Raspberry Pi running softsynths.
Now, my target is to make a multitimbral portable music making tool with Daisy. I am going to do it in three steps:
  1. Prototype: Something static and self contained (nothing except the Seed)
  2. Usable: Programmable using an LCD Keypad, save patterns and sounds
  3. Finished: GATE IN/OUT, some pots for editing and live control, LFOs
Before I enter step 1, I’ve been doing an experiment. I’ve made a simple MIDI engine using the Metro class. It plays a small drum machine, a bass and an arpeggio. The drums are synthesized (kick, snare and open/closed hihat). Two synths are running right now, controlled by MIDI values in arrays holdings 16ths. So all in all 4 oscillators, 2 noise generators, 8 envelopes, 4 filters. Mixed in simple “stereo” out.
Maybe this experimental code can be interesting and/or useful for someone making something similar.
If there is any interest, I’ll provide updates on my progress! :slight_smile:
https://oscillator.se/sites/default/files/opensource/oscpocketd.zip
Thanks,
Staffan
I’ve added 2 more synths with their own MIDI engine, data entered (in code) as {pitch, duration}.
So, drum machine (2 osc’s, 2 noise) + 4 synths (4 osc’s).
Next I will add a chord track, then focus on getting an UI running on an LCD Keypad so the sequences and synth settings can be edited.
OK, so the chord engine is alive, very simple, using 3 osc’s.
Status: running drum machine (2 osc’s, 2 noise) + 2 x bass + 2 x lead + 1 x chord (3 osc) = 9 osc’s.
Some problems remain, but most of all, I have to get an UI running so I will focus on that now.
(Same link to source as original post.)
Short demo: https://youtu.be/IEzufs4jgXI.
Step 1 - Prototype completed.
11+2 voices running now, all sequenced. New song mode added, where 2 bar sequences can be chained in any order.
YouTube:
https://youtu.be/TvxvXqrM678
Next: Step 2 - Usable. I will create the UI, using the LCD library I wrote (LCD class for a 16x2 LCD using the Hitachi HD44780 driver chip).
It is sounding a bit too much chip-tune for my taste, but the UI will include editable parameters for all oscillators, including the VA drums.
It looks promising, I already built your OscPocket on the Arduino and would like to test it once released :wink:
Thanks @autodafe! As you noticed it has some similarities with my Arduino project, but the power of the Daisy makes it possible to do so much more with just one Daisy! :slight_smile:
At the same time I want to keep the cost down, you will only need the Daisy Seed + LCD Keypad + 2-3 audio connections.
I will add a SYNC IN (GATE) so you will be able to let the OscPocketO work with the OscPocketD.
Thank you for your interest!
I’ve built a simple circuit with the Daisy and the necessary parts. Front and back attached.
The UI is operated with the buttons on the LCD Keypad, which I now read successfully in the code.
The extra single button is a reset-to-bootloader (BOOT_FLASH attached to a pin?) which makes reprogramming a lot easier.
The three extra audio sockets will potentially be used for: SYNC IN (GATE/CLOCK), MIDI and Audio In.
I’ve also left some space for 2-3 pots.
Now only the UI/edit code remains (great fun!), but work starts Monday, so… :frowning:
