My cat broke off USB connector on Daisy Seed
Just in case anyone else decides to (or is forced to) abandon flashing their programs through the USB connector on the Daisy Seed and use a STLINK V3 MINI, here’s some information that may help.
  1. The v3 mini comes with a 14 pin connector cable that must be centered on the 10 pin Daisy header.
  2. The cable must be oriented so that the wire with the red stripe is closest to the ARM chip.
  3. The v3 mini does not supply power to the Daisy. You must supply power either through the USB port or by Vin (physical pin 39).
If you’re using Arduino IDE
  1. You don’t need to install any additional software on top of what is already required to use the USB port for loading your program to the Daisy.
  2. You need to change Upload Method from DFU to SWD (see attached screen shot).
I hope this lowers somebody’s learning curve or frustration factor. :slightly_smiling_face:
